MD7790 - MOPAR 8 3/4 AND DANA 60 REAR DISC BRAKE CONVERSION SET WITHOUT PARKING BRAKE
Looking to convert your Mopar to rear disc brakes? This complete rear disc conversion set has what you need for an easy conversion.
Set includes: •Single piston loaded rear calipers
•Dana 60 and 8-3/4" rear end caliper brackets
•Standard rear rotors with 5 X4-1/2" bolt pattern
•Rubber flex hoses
•Mounting hardware
Important: Requires "Green" bearings part # + Learn More
Product #: MD7790
In Stock Now!
MSRP: $379.99 set
Classic: $344.99 set
Quantity:
Add to Wishlist
Oversize Freight Type:
Oversize
Share:
Additional Info
Also Fits
Ask A Tech
MOPAR 8 3/4 AND DANA 60 REAR DISC BRAKE CONVERSION SET WITHOUT PARKING BRAKE - Continued
•Rubber flex hoses
•Mounting hardware
Important: Requires "Green" bearings part # MM3063 (sold separately) on models with 8-3/4" rear ends.
Note: Minimum 15" wheels required. Shipped oversize
-----------Found this @ Classic industries
