Re: rear disc brake conversion [Re: mr_340] #1765396
03/07/15 09:33 PM
03/07/15 09:33 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Heyyyyyyy !!!!
I just tried them on 5 min ago......
I have the same problem! someting need to be done there lollll
The bracket is too long, or I need 11 3/4 rotors too........
Anyone has comments on that ?
Re: rear disc brake conversion [Re: Wedgeman] #1765397
03/07/15 10:13 PM
03/07/15 10:13 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
MD7790 - MOPAR 8 3/4 AND DANA 60 REAR DISC BRAKE CONVERSION SET WITHOUT PARKING BRAKE
Looking to convert your Mopar to rear disc brakes? This complete rear disc conversion set has what you need for an easy conversion.
Set includes: •Single piston loaded rear calipers
•Dana 60 and 8-3/4" rear end caliper brackets
•Standard rear rotors with 5 X4-1/2" bolt pattern
•Rubber flex hoses
•Mounting hardware
Important: Requires "Green" bearings part # + Learn More
Product #: MD7790
In Stock Now!
MSRP: $379.99 set
Classic: $344.99 set
Quantity:
Add to Wishlist
Oversize Freight Type:
Oversize
Share:
Additional Info
Also Fits
Ask A Tech
MOPAR 8 3/4 AND DANA 60 REAR DISC BRAKE CONVERSION SET WITHOUT PARKING BRAKE - Continued
•Rubber flex hoses
•Mounting hardware
Important: Requires "Green" bearings part # MM3063 (sold separately) on models with 8-3/4" rear ends.
Note: Minimum 15" wheels required. Shipped oversize
-----------Found this @ Classic industries
Yeah, it's got a smallblock.
Re: rear disc brake conversion [Re: mr_340] #1765398
03/07/15 11:54 PM
03/07/15 11:54 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I was looking at the 1993 Jeep rotors and they appear to be close to 11" diameter and the brackets seem to be designed for the larger 11-3/4" rotors. Do the brackets need to be re-radiused to move the calipers closer to the axle centerline by 3/8"?
Sure looks like it !...
Better to push the bracket toward the calipers and drill 2 other holes for the brake pins......
Dan
Re: rear disc brake conversion [Re: Wedgeman] #1765399
03/08/15 01:04 AM
03/08/15 01:04 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Those GM calipers didn't work well new,what has changed that would want me to put them on the back of my 3900 lb car that goes 140+ in the 1/4 mile??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: rear disc brake conversion [Re: hemi-itis] #1765400
03/08/15 02:01 PM
03/08/15 02:01 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Yes I moved mine down closer to the rotor
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: rear disc brake conversion [Re: toplescuda] #1765401
03/08/15 04:24 PM
03/08/15 04:24 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I cut the radius 5/8 in closer to the axle so the pads fully contact the rotors.
I made a fitting to plug into the air hose and apply pressure on the rotor to square it, works like a charm !
Tac weld, remove the calipers and fully weld on both sides...
Re: rear disc brake conversion [Re: Wedgeman] #1765402
03/08/15 05:15 PM
03/08/15 05:15 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Randy
Re: rear disc brake conversion [Re: Dartin] #1765403
03/08/15 08:09 PM
03/08/15 08:09 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thanks bud !
Dan
