Re: rear disc brake conversion
[Re: Wedgeman]
#1765381
02/28/15 07:52 PM
02/28/15 07:52 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I used 95 jeep grand Cherokee for the rotors 88 bucks for the pair. 92 s10 caliper 11 bucks each and bracket from jegs. Was like 12-15 bucks
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: Wedgeman]
#1765397
03/07/15 10:13 PM
03/07/15 10:13 PM
Posts: 1,532 off the grid
340B5
off the grid
MD7790 - MOPAR 8 3/4 AND DANA 60 REAR DISC BRAKE CONVERSION SET WITHOUT PARKING BRAKE Looking to convert your Mopar to rear disc brakes? This complete rear disc conversion set has what you need for an easy conversion. Set includes: •Single piston loaded rear calipers •Dana 60 and 8-3/4" rear end caliper brackets •Standard rear rotors with 5 X4-1/2" bolt pattern •Rubber flex hoses •Mounting hardware Important: Requires "Green" bearings part # + Learn More Product #: MD7790 In Stock Now! MSRP: $379.99 set Classic: $344.99 set Quantity: Add to Wishlist Oversize Freight Type: Oversize Share: Additional Info Also Fits Ask A Tech . MOPAR 8 3/4 AND DANA 60 REAR DISC BRAKE CONVERSION SET WITHOUT PARKING BRAKE - Continued Looking to convert your Mopar to rear disc brakes? This complete rear disc conversion set has what you need for an easy conversion. Set includes: •Single piston loaded rear calipers •Dana 60 and 8-3/4" rear end caliper brackets •Standard rear rotors with 5 X4-1/2" bolt pattern •Rubber flex hoses •Mounting hardware Important: Requires "Green" bearings part # MM3063 (sold separately) on models with 8-3/4" rear ends. Note: Minimum 15" wheels required. Shipped oversize -----------Found this @ Classic industries
Yeah, it's got a smallblock.
[Re: mr_340]
#1765398
03/07/15 11:54 PM
03/07/15 11:54 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
I was looking at the 1993 Jeep rotors and they appear to be close to 11" diameter and the brackets seem to be designed for the larger 11-3/4" rotors. Do the brackets need to be re-radiused to move the calipers closer to the axle centerline by 3/8"?
Sure looks like it !...
Better to push the bracket toward the calipers and drill 2 other holes for the brake pins......
Dan
[Re: hemi-itis]
#1765400
03/08/15 02:01 PM
03/08/15 02:01 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Yes I moved mine down closer to the rotor
