cal-tracs and transbrakes #1764529
02/27/15 04:36 PM
02/27/15 04:36 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone here using cal-tracs and launching off transbrake? I know john calvert doesn't recommend it, but i'm curious if anyone is making it work.
Re: cal-tracs and transbrakes [Re: mopar dave] #1764530
02/27/15 05:03 PM
02/27/15 05:03 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I think there are plenty of guys using this setup. Dustin Ward, AKA: triplethreat, has cal-tracs and a brake on his dart, and has been deadly with it.
Just thinking in my mind of how the Cal-Trac setup works, I would think it would work pretty well, because the harder you hit it, the more its gonna plant the tire. (???).
Re: cal-tracs and transbrakes [Re: mopar dave] #1764531
02/27/15 05:15 PM
02/27/15 05:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I know S/S springs worked excellent for me with a brake, I would sure hope a more high dollar setup would
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: cal-tracs and transbrakes [Re: B3422W5] #1764532
02/27/15 06:10 PM
02/27/15 06:10 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
We suggest using a adjustable rear shock, and setting the rebound side to one of the lightest settings, on our 9-way adjustable shock, we say to use between 1 and 3, one being the lightest setting.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: cal-tracs and transbrakes [Re: johnnycuda] #1764533
02/27/15 07:04 PM
02/27/15 07:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you know when/if the single adj. ft.`s are coming out?
Re: cal-tracs and transbrakes [Re: Thumperdart] #1764534
02/27/15 07:12 PM
02/27/15 07:12 PM
johnnycuda Offline
johnnycuda  Offline
Hey Dom, the front adjustables are on hold for now, back in R&D, John wasn't happy with the performance of the samples he had had made.
Re: cal-tracs and transbrakes [Re: johnnycuda] #1764535
02/27/15 07:17 PM
02/27/15 07:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good 2 know.................
Re: cal-tracs and transbrakes [Re: B3422W5] #1764536
02/27/15 11:35 PM
02/27/15 11:35 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I ran a T/B with SS spring before going to ladder bars and the car twisted to the point that a bubby of mine thought the rear window were going to pop
Re: cal-tracs and transbrakes [Re: racerx] #1764537
02/28/15 12:34 AM
02/28/15 12:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizusters turbo car runs trans brake, Cal Tracks and radials. Good shocks are the key. Going to Menser valved Afco's was worth 2 tenths in 60 ft. Not to mention that it is very consistent.
Doug
Re: cal-tracs and transbrakes [Re: racerx] #1764538
02/28/15 12:42 AM
02/28/15 12:42 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Put a brake in my 3350 pound Duster in 2003 running 9's sold the car in 2011, still has the brake in it with new owner, is straight as an arrow, and has had hundreds of passes put on it during that time. Plenty of guys on here have seen/ know the car.
If your car was twisting up you had/ have something going on with the cage/ interconnection of the chassis/ frame connectors.
1.41 best 60 foot
6.56 at 104.17
Re: cal-tracs and transbrakes [Re: StealthWedge67] #1764539
02/28/15 12:49 AM
02/28/15 12:49 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks and good to know its a combo that can work. john calvert told me that the cal-tracs need to be preloaded before launch. so I wired the 2 step to a micro switch on my footbrake. I may just rewired back to the transbrake and turn it up.
Re: cal-tracs and transbrakes [Re: mopar dave] #1764540
02/28/15 12:59 AM
02/28/15 12:59 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
What were you using before the caltracs?
1.41 best 60 foot
6.56 at 104.17
Re: cal-tracs and transbrakes [Re: B3422W5] #1764541
02/28/15 01:00 AM
02/28/15 01:00 AM
Mt Morris Michigan
Mt Morris Michigan
ss springs and footbrake. that was years ago.
Re: cal-tracs and transbrakes [Re: mopar dave] #1764542
02/28/15 01:05 AM
02/28/15 01:05 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
At the ET you are shooting for, the S/S springs you had would have worked fine, well into the 9's easily. If the car hooks, the ET difference won't amount to anything.
1.41 best 60 foot
6.56 at 104.17
Re: cal-tracs and transbrakes [Re: B3422W5] #1764543
02/28/15 01:39 AM
02/28/15 01:39 AM
Mt Morris Michigan
Mt Morris Michigan
Yeah I know. Too bad I figured that out after I bought the Cal tracs. I used to talk to a guy on another forum that had a duster with ss springs in the very low 9s.
Re: cal-tracs and transbrakes [Re: B3422W5] #1764544
02/28/15 01:55 AM
02/28/15 01:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
It's been so long ago can't remember if it was cage or just a roll bar but I do remember it having a set of stock truck shocks...Lol
