622 starter recommendations / experiences #1764011
02/26/15 11:23 PM
02/26/15 11:23 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
What starters are you using on BIG CI engines?? Looking for a starter for 622 wedge. It has 11.5-1 compression. I have Mopar mini starter but don't think it has enough oomph. Looking at Powermaster 9523. Also see MSD has starters now too.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: 622 starter recommendations / experiences [Re: steve660] #1764012
02/26/15 11:27 PM
02/26/15 11:27 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I use a mopar mini starter on my 605, it's only 10.4-1. No problems what so ever. Dave
Re: 622 starter recommendations / experiences [Re: steve660] #1764013
02/27/15 12:08 AM
02/27/15 12:08 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Is that #9523 the one that is 'clockable/indexable' for clearance issues?? If it is,,,,, ....GOOD LUCK with it!! I had one,,,,3-4 times off & on and back to them for repairs/upgrades/etc. I finally threw it in the junk and used a Mopar mini. The Powerbastard lasted about 15 starts the first time before it broke. The next couple of times less than 15 and then ate up my ring gear on my convertor. Mopar mini has been on for over 4 years with NO problems. 493" 13.5:1
If you like drag racing, support your local track.
Re: 622 starter recommendations / experiences [Re: CHAPPER] #1764014
02/27/15 12:58 AM
02/27/15 12:58 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
No 9523 isnt the clockable one. That one looks like a PITA!! Maybe the Mopar mini starter is the way to go.....
Re: 622 starter recommendations / experiences [Re: steve660] #1764015
02/27/15 05:21 AM
02/27/15 05:21 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
i bought this special meziere ts306....none better
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: 622 starter recommendations / experiences [Re: quickd100] #1764016
02/27/15 12:39 PM
02/27/15 12:39 PM
an8sec70cuda Offline
Same here on my 572" 11:1 motor. Used the same starter on my 14.5:1 446" motor too. Never had any issues after many years on the same starter.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 622 starter recommendations / experiences [Re: steve660] #1764017
02/27/15 12:50 PM
02/27/15 12:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That Mopar starter should be fine... check your wiring
for good grounds .. what size wire did you run to
the starter
Re: 622 starter recommendations / experiences [Re: MR_P_BODY] #1764018
02/27/15 01:19 PM
02/27/15 01:19 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Ok thanks Chip. Ill run the Mopar mini.
Mr. P....I'll have to check.. Its either a 1 or 0 gauge cable to the starter. Ive ran the mini starter on my old 496 for years without problems. Guess it's tougher than I thought. Thanks guys, ya just saved me $250!!!
Re: 622 starter recommendations / experiences [Re: steve660] #1764019
02/27/15 01:24 PM
02/27/15 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure you have a good ground going to the block..
large enough to carry the starter load
