Re: Something hitting, can't tell what...
[Re: I_bleed_MOPAR]
#1764000
03/01/15 01:55 PM
03/01/15 01:55 PM
Posts: 1,723 North Austin
KnuckleDuster
North Austin
As shown in the video,the shield isn't on there. Here's a pic of clearance to the windage tray. Another... One more...
[Re: CrazyD]
#1764002
03/01/15 05:41 PM
03/01/15 05:41 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Sorry. Didn't watch the video as it never would play for me. Did you see Johns post asking about converter depth?
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1764003
03/01/15 07:04 PM
03/01/15 07:04 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
Cannot tell how close it is from the pic angles, but could it be pickup tube rattling against the windage tray?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: KnuckleDuster]
#1764004
03/01/15 07:27 PM
03/01/15 07:27 PM
RapidRobert
As noted the only thing(s) that were changed that took it from quiet to hitting was welding the baffles in the pan and the TC change? No pan change?, no w tray change?, no pump change (gasket/no gasket between pump/#5 cap)?, no bending of w tray?. I couldn't play the video either, they wanted me to subscribe . The pan baffles are all well below the w tray correct? Same pan gasket (thickness in other words). The tinny sound sure sounds like w tray but sounds like your visual (not the pics) is looking OK there. I'd stay on the TC/shield. Keep us posted. Are you SURE nothing is hitting the tray? EDIT wouldn't that be a bite if it IS the dipstick
[Re: RapidRobert]
#1764005
03/01/15 09:04 PM
03/01/15 09:04 PM
KnuckleDuster
North Austin
It's in the pan near the #3 cap, I can feel it now. I think baffles tweaking the tray nailed it... Rod bolt bareley kissing the tray. Looking at my pics the tray looks slightly elliptical. The pickup was a little loose but I tightened it another 360°, and doubt it would transmit through the pan so well. I guess I just couldn't pinpoint it yesterday, but today I can press on the pan and hear a very slight tone change. I guess I get to pull the whole deal out again. I really hoped it was bolts rubbing but after watching it run with a maglight I can see they are not even close to hitting anything.
[Re: KnuckleDuster]
#1764007
03/10/15 05:38 PM
03/10/15 05:38 PM
KnuckleDuster
North Austin
Looks like the tang over the oil pump on the windage tray got pushed in on the driver side and the #5 rod was just grazing it.I pulled it back out with my pinky.Probably bumped it over installing the pan, tray is so malleable...grrrr...nothing but noise. Don't see a need for the tray with the Kevko pan while it's apart,so deleting the tray. Can I use my piston stop to block the engine up to tighten my converter bolts without damaging the forged aluminum piston,or should I use rope in the cylinder?
[Re: stumpy]
#1764009
03/11/15 02:40 AM
03/11/15 02:40 AM
Posts: 10,233 Someplace you aren't
SomeCarGuy
Stick a hammer handle in the way of the crank. Back off crank once done, then roll the engine forward again
I want my fair share
