Re: Something hitting, can't tell what...
[Re: KnuckleDuster]
#1763984
02/26/15 10:31 PM
02/26/15 10:31 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
My guess. Tight enough to turn over the engine isn't tight enough. Lock the flexplate with a vice grip or a screw driver to hold the converter in place.
I have mechanical Aptitude. I can screw up anything.
[Re: KnuckleDuster]
#1763989
02/28/15 06:55 PM
02/28/15 06:55 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Run it again. Put your fingers on the side of the pan and see if you can feel the same pattern as the sound.
The other option would be to use a piece of tubing as a stethescope and listen for the noise in the pan.
[Re: KnuckleDuster]
#1763990
02/28/15 06:56 PM
02/28/15 06:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Rod knock is more of a thunk, thunk, thunk and not a ting.
[Re: feets]
#1763991
02/28/15 07:03 PM
02/28/15 07:03 PM
Posts: 1,723 North Austin
KnuckleDuster
North Austin
I did feel it all over,even put my ear against the pan,can't even pinpoint where it's coming from.
It is a very tinny sound...makes me think very light contact but infuriating.
[Re: KnuckleDuster]
#1763992
02/28/15 07:44 PM
02/28/15 07:44 PM
Posts: 15,414 Omaha Ne
TJP
Omaha Ne
I did not hear this before I did the baffles and converter
My bet is on the baffles
[Re: KnuckleDuster]
#1763993
02/28/15 07:47 PM
02/28/15 07:47 PM
Posts: 25,864 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you installed the converter to the flexplate how much pull-up was there? IOW, with the converter pushed as far as it would go into the trans, how much air gap (pull-up) was there between the drive lugs and the flexplate?
If little/none the converter bowl could be rubbing the pump casting.
[Re: KnuckleDuster]
#1763997
02/28/15 09:16 PM
02/28/15 09:16 PM
TJP
Omaha Ne
The only baffles left are a small dam at the rear of the sump, covered by the windage tray. They are welded in and don't move.
Maybe the baffles are tweaking the windage tray and causing the interference???
You have two changes/scenarios, Baffles, or converter, bolts, flex plate and/or bolts ETC. Your description sounds more like a lower end interference with sheet metal IMO. hard to diagnose over a webpage but
I chased a noise several year back that wound up being a rod bolt BARELY kissing the pan. A tweak with a hammer and all was good. The rub mark was BARELY visible to the naked eye but it was NOISY!!! Good luck and keep us posted
[Re: TJP]
#1763998
03/01/15 03:09 AM
03/01/15 03:09 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Do you have the stone shield installed? I had one that was cracked and would fall back intermittently into the convertor area. Made strange sound no fewer than 10 pro and advanced shade tree mechanics declared was everything from a dying engine to fried trans. You had the trans pulled so maybe it was damaged.
I want my fair share
[Re: SomeCarGuy]
#1763999
03/01/15 01:16 PM
03/01/15 01:16 PM
Posts: 8,672 Buford, GA
I_bleed_MOPAR
Buford, GA
^^^^^^ This. The small shield on the 383 would rub the converter bolts. Had to flatten a rib on it to stop the noise. I know you painted the bolt heads but maybe the shield is hitting the flex plate or converter?
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
