1969 440 HiPo manifold to exhaust pipe flange gasket #1763567
02/26/15 01:52 PM
02/26/15 01:52 PM
st louis mo
Q5Bee B5ScatPack Offline OP
st louis mo
ok,i have always used headers or had cars that had complete exhaust systems on them which gasket to use for hipo manifold to exhaust pipe flange,donut or flat?
Re: 1969 440 HiPo manifold to exhaust pipe flange gasket [Re: Q5Bee B5ScatPack] #1763568
02/26/15 02:01 PM
02/26/15 02:01 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Should be a flat gasket. There are two different ones listed. The low performance log manifold gaskets are smaller and the high performance manifold flange gasket is larger.
Matt
Re: 1969 440 HiPo manifold to exhaust pipe flange gasket [Re: Q5Bee B5ScatPack] #1763569
02/26/15 02:11 PM
02/26/15 02:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
flat , 2.5" ID
Re: 1969 440 HiPo manifold to exhaust pipe flange gasket [Re: JohnRR] #1763570
02/26/15 05:31 PM
02/26/15 05:31 PM
st louis mo
st louis mo
1969 SUPERBEE 383 Q5 RED STRIPE WHITE INT.
2015 CHALLENGER SCAT PACK B5 BLUE
1996 INDY RAM PACE TRUCK
Re: 1969 440 HiPo manifold to exhaust pipe flange gasket [Re: JohnRR] #1763571
02/26/15 07:20 PM
02/26/15 07:20 PM
AndyF Offline
AndyF  Offline
If you have 3" headpipes then you have to use a Ford pickup exhaust gasket. The bolt pattern is close enough to work but the ID is 3".
Re: 1969 440 HiPo manifold to exhaust pipe flange gasket [Re: AndyF] #1763572
02/26/15 08:36 PM
02/26/15 08:36 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Felpro # 60025
McCord # 82 0051
Detroit# 13043
Victor # F 5561K
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
