How to freshen up an A500? #1762936
02/25/15 07:51 PM
02/25/15 07:51 PM
mn
flyman Offline OP
flyman  Offline OP
mn
So I picked up a 1993 Dakota as a parts car for my 1957 truck project
, The a500 trans works fine but as long as it is out, What should I do to freshen it up? I will be putting new fluid and filter for sure. Any other ideas to keep it running well?
Re: How to freshen up an A500? [Re: flyman] #1762937
02/25/15 08:30 PM
02/25/15 08:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Filter and fluid should be all that is necessary. It's essentially a 904 with an overdrive compounder hanging off the back.
- Stu Harmon
Re: How to freshen up an A500? [Re: feets] #1762938
02/25/15 08:59 PM
02/25/15 08:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would add to adjust the bands while you have the pan off, tighten up the line pressure screw a couple turns (the spring loses a little tension over the years)and use type-F fluid. There are some other respected trans guys who say no to the type-f but my experience says use it.
Re: How to freshen up an A500? [Re: HotRodDave] #1762939
02/26/15 01:38 AM
02/26/15 01:38 AM
mn
flyman Offline OP
flyman  Offline OP
mn
Thanks Guys
Re: How to freshen up an A500? [Re: flyman] #1762940
02/26/15 02:19 AM
02/26/15 02:19 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Only time I ever tried type F was after taking a running 727 down for a band adjustment, fluid and filter change. Next day all the friction material came off my clutches. So I wouldn't use it myself, except maybe on a fresh rebuild with new friction material.
If your 500 is a lockup clutch one then expect some shudder when not using the specified fluid as well.
Don't be the exception.
Re: How to freshen up an A500? [Re: flyman] #1762941
02/26/15 02:56 AM
02/26/15 02:56 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd tear it down and get it out of the way for some years. Changing fluid and such won't fix an older unit with dead seals etc. IF you have used this unit and happy with it,run it.
Re: How to freshen up an A500? [Re: HotRodDave] #1762942
02/26/15 04:18 PM
02/26/15 04:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Type F fluid is inappropriate for any OD transmission.
Re: How to freshen up an A500? [Re: John_Kunkel] #1762943
02/26/15 07:50 PM
02/26/15 07:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
John is one of the guys who knows more than me about these trannys.
John I just almost never see OD bearing/gear problems here, maybe because it is way cooler than where you live? Mostly clutch and band failure
Re: How to freshen up an A500? [Re: HotRodDave] #1762944
02/27/15 04:28 PM
02/27/15 04:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Classic case of doing it wrong and getting away with it versus doing it right.
OD transmissions need the lubricating properties of the fluid that's designed for them....Type F has the least lubricating properties of them all.
Re: How to freshen up an A500? [Re: John_Kunkel] #1762945
02/28/15 04:25 PM
02/28/15 04:25 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
So what is the best type fluid to run in a 500 or 518 trans? ATF+ or Dexron ?
Re: How to freshen up an A500? [Re: JDMopar] #1762946
02/28/15 05:05 PM
02/28/15 05:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think the early ones call for dexron and by the end they were calling for mopar +4.
