Re: How to freshen up an A500?
[Re: flyman]
#1762937
02/25/15 08:30 PM
02/25/15 08:30 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Filter and fluid should be all that is necessary. It's essentially a 904 with an overdrive compounder hanging off the back.
[Re: feets]
#1762938
02/25/15 08:59 PM
02/25/15 08:59 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would add to adjust the bands while you have the pan off, tighten up the line pressure screw a couple turns (the spring loses a little tension over the years)and use type-F fluid. There are some other respected trans guys who say no to the type-f but my experience says use it.
[Re: HotRodDave]
#1762939
02/26/15 01:38 AM
02/26/15 01:38 AM
Posts: 189 mn
flyman
mn
[Re: flyman]
#1762940
02/26/15 02:19 AM
02/26/15 02:19 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Only time I ever tried type F was after taking a running 727 down for a band adjustment, fluid and filter change. Next day all the friction material came off my clutches. So I wouldn't use it myself, except maybe on a fresh rebuild with new friction material.
If your 500 is a lockup clutch one then expect some shudder when not using the specified fluid as well.
[Re: HotRodDave]
#1762942
02/26/15 04:18 PM
02/26/15 04:18 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Type F fluid is inappropriate for any OD transmission.
[Re: John_Kunkel]
#1762943
02/26/15 07:50 PM
02/26/15 07:50 PM
HotRodDave
Kalispell Mt.
John is one of the guys who knows more than me about these trannys. John I just almost never see OD bearing/gear problems here, maybe because it is way cooler than where you live? Mostly clutch and band failure
[Re: HotRodDave]
#1762944
02/27/15 04:28 PM
02/27/15 04:28 PM
John_Kunkel
Rio Linda, CA
Classic case of doing it wrong and getting away with it versus doing it right.
OD transmissions need the lubricating properties of the fluid that's designed for them....Type F has the least lubricating properties of them all.
[Re: JDMopar]
#1762946
02/28/15 05:05 PM
02/28/15 05:05 PM
HotRodDave
Kalispell Mt.
I think the early ones call for dexron and by the end they were calling for mopar +4.
