Re: Full Length Fuel/Brake Lines, Who Is The Best????
[Re: bronze69]
#1761495
02/23/15 07:17 PM
02/23/15 07:17 PM
Posts: 1,032 Ohio
dobie
Ohio
I used The Right Stuff SS brake and fuel lines on mine. Fit great and zero leaks.
1968 Plymouth Road Runner
383 4 speed
[Re: RagtopChallenger]
#1761498
02/23/15 09:03 PM
02/23/15 09:03 PM
Posts: 2,131 New Mexico
JMCFAN
New Mexico
I used Inline Tubes... no issues. Nice fit
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: gtx6970]
#1761505
02/25/15 09:02 PM
02/25/15 09:02 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I get right stuff from summit, never had a problem with the lines and get it shipped free
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1761506
02/25/15 09:49 PM
02/25/15 09:49 PM
Posts: 606 Mass
charge70
Mass
Another vote for Fine Lines John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: RP's R/T's]
#1761510
03/02/15 12:28 PM
03/02/15 12:28 PM
Posts: 2,484 Minneapolis, MN
hemi70se
Minneapolis, MN
I have always bought the OE material instead of the Stainless. I had heard that the hardness of the stainless created issues sometimes with getting a good seal at connections. Also, I thought, if the crappy originals lasted 35 years and 80,000 miles, surely the new ones will last longer when it is stored in a climate controlled garage and driven 1500 miles a year.
I agree!! More correct looking and cost less! We don't expose our cars to the elements like they were the first time around.
[Re: RP's R/T's]
#1761511
03/02/15 02:27 PM
03/02/15 02:27 PM
Posts: 18,166 Mass
DAYCLONA
Mass
Generally the problem associated with sealing stainless steel lines/fittings for a leak proof fit is an improper installation, no oil or lube on the threads, along with using a "standard" wrench, rather than the proper tube wrench, no lube the threads gall, therefore you can't tighten the fitting because it's galled on the threads binding, then most will compound the issue using a "standard" wrench, which "eggs" the tube fitting, which now causes the tube double flare to "egg" on the flare fitting, then nothing but leaks, and then the irate (often inept/uneducated)end user has nothing but disdain for SS lines
I personally prefer SS lines, they can be easily polished bright for a custom look, or brushed/scotchbrited down to look like OEM steel lines, and granted most restored rides won't see the mileage that they may have seen originally, what they will see however is longer periods of dormant sitting where any water moisture trapped in the brake fluid can/will rot steel lines from the inside out, I've seen it before on long term storage vehicles with "new" steel lines...I've never had an issue using/forming/flaring SS lines
[Re: RP's R/T's]
#1761512
03/02/15 05:26 PM
03/02/15 05:26 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I have scotch-brited, and cleared OEM lines...
They did not hold up at all...
My experience with SS has been multiple sealing issues...
Flares not as forgiving as 'softer' OEM steel...
My experience with In Line Tube has not been good...
