Lights out 6
#1761157
02/23/15 10:30 AM
02/23/15 10:30 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Had a great time at SGMP this week end. Sorry Jason nipped a head gasket Friday night and couldn't find a replacement in time. Some killer racing going on, and Donald Long takes care of his spectators like nobody else.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Lights out 6
[Re: J_BODY]
#1761162
02/23/15 02:20 PM
02/23/15 02:20 PM
Quicktree
man I wanted to go, but had sea school all weekend ![](/ubbthreads/images/graemlins/tongue.gif) but you guys can call me Captain from now on ![](/ubbthreads/images/graemlins/laugh2.gif) (thats if I pass the test ![](/ubbthreads/images/graemlins/laugh2.gif) )
Re: Lights out 6
[Re: JERICOGTX]
#1761167
02/23/15 03:42 PM
02/23/15 03:42 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Had a blast also, will go the whole weekend next time, should have the suite reserved again for No Mercy also ![](/ubbthreads/images/graemlins/beer.gif)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Lights out 6
[Re: JERICOGTX]
#1761171
02/23/15 06:26 PM
02/23/15 06:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Why no wheelie bars?
EGO...
IMO The Camaro that went airborne would have been saved with bars.
Has NOTHING to do with ego or "stupidity". Most radial racing, wheelie bars are NOT allowed, so these cars are set up to run without them. While they are allowed at THIS race in THIS class, most choose not to use them, because they never have.
I have seen Dewayne Mills car make hundreds of passes. NEVER seen it do that. He said it pushed the front up a little because of a new trans gear set up he was trying and then the throttle hung. Plus, at that speed, it would have just folded the bars up anyway, just as it did on the Mustang that did the same thing down there a few years ago. These cars run nearly 200 in the 1/8 and they are heavy. You get a big gulp of air under a car that fast, at that weight, it IS going airborne and bars would NOT save it.
Monte
Re: Lights out 6
[Re: Monte_Smith]
#1761172
02/23/15 06:28 PM
02/23/15 06:28 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Monte, I was gonna say hello a few times but you looked cold, busy or both
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Lights out 6
[Re: Monte_Smith]
#1761173
02/23/15 06:29 PM
02/23/15 06:29 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
EGO...
Monte
Monte...would it have even got up high enough to catch air if the bars were low enough to keep the car down in the first place?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Lights out 6
[Re: Eric]
#1761176
02/23/15 06:59 PM
02/23/15 06:59 PM
Monte_Smith
North Alabama
EGO...
Monte
Radial cars are NOT set up to run bars. If they touch early, it knocks the tires off. Therefore the guys that DO use them at times, in testing or whatever, run them high and are only useful early in the run. What has not been stated, was that this happened at about the 400 ft mark. The car was making a nice clean pass, with the front wheels about 4" in the air like it always does. Then it just quickly snapped the front up. At that speed, with bars a foot or so off the ground, they would have never even slowed it down. As I said, the same thing happened to Dennis Bailey a few years ago and his car had bars. When this happens, the FULL weight of the car is on the bars........they simply fold up.
This was NOT a wheelstand per say. The car just got the front up a little, air got under it and it "flew". We see it happen in Pro-Stock and cup cars all the time. Get a cushion of air under them and they are GONE. Most of the cars have full belly pans. That's an awful big "wing" to catch air running at nearly 200
Monte
