63 max wedge oil pickup #1761086
02/23/15 02:59 AM
02/23/15 02:59 AM
California
mickm Offline OP
mickm  Offline OP
California
is there anything different about this pickup, length and such? have one that isn't in the best of shape, would need to be taken apart and given a little loving care. if it is easy to get a replacement, that would be better.
Re: 63 max wedge oil pickup [Re: mickm] #1761087
02/23/15 03:42 AM
02/23/15 03:42 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Max Wedge would have a swinging pickup , is that what you have ?
Re: 63 max wedge oil pickup [Re: mickm] #1761088
02/23/15 03:48 AM
02/23/15 03:48 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
63 max pickup
Re: 63 max wedge oil pickup [Re: srt] #1761089
02/23/15 04:52 AM
02/23/15 04:52 AM
63 max pickup
Those rascals be air sucking engine killers Your a lot better off buying a fix street hemi pickup and shortening it to make it fit properly You need the proper M.W. oil pan to go along with those picksups also, not a stock 361/413 oil pan either
Re: 63 max wedge oil pickup [Re: Cab_Burge] #1761090
02/23/15 06:15 PM
02/23/15 06:15 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Agree that they can suck air.
Atttached is the pan with central sump that has baffle plates front and rear to keep oil from sliding out of the sump during accel/deaccel/turning.
The motor was set on the pan and the middle is a little pushed up.
Re: 63 max wedge oil pickup [Re: srt] #1761091
02/23/15 06:17 PM
02/23/15 06:17 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
baffles
Re: 63 max wedge oil pickup [Re: srt] #1761092
02/23/15 08:13 PM
02/23/15 08:13 PM
California
mickm Offline OP
mickm  Offline OP
California
63 max pickup
i've never seen a pickup like this. the pickup we have looks like a regular 1/2" pickup.
we do have an original 63 pan, hard to tell exactly, but it does look like the one in the pictures on this thread.
Re: 63 max wedge oil pickup [Re: Cab_Burge] #1761093
02/23/15 08:15 PM
02/23/15 08:15 PM
California
mickm Offline OP
mickm  Offline OP
California
63 max pickup
cab, as mentioned, we have the correct pan, (i know, i was there when he paid an ungodly amount of money for it!). so a regular 1/2" pickup will work, just shortened to the correct length?
Re: 63 max wedge oil pickup [Re: mickm] #1761094
02/24/15 02:17 PM
02/24/15 02:17 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Many would suggest deepen the pan instead. Oil starvation is a potential problem.
Re: 63 max wedge oil pickup [Re: srt] #1761095
02/24/15 03:33 PM
02/24/15 03:33 PM
California
mickm Offline OP
mickm  Offline OP
California
it's a stock 63 pan, modifying that would be a no-no. and he is going to use it. this will be a street car and will not see much high rpm usage, so that pan will work for what he is after.
Re: 63 max wedge oil pickup [Re: mickm] #1761096
02/24/15 05:23 PM
02/24/15 05:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On the last MW I built with the correct pan I used a shortened Hemi rigid pickup as Cab suggested.
Re: 63 max wedge oil pickup [Re: mickm] #1761097
02/24/15 05:41 PM
02/24/15 05:41 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I should have clarified.
Didn't mean to deepen the original pan, get a pan with central sump and deepen that.
Re: 63 max wedge oil pickup [Re: John_Kunkel] #1761098
02/24/15 05:46 PM
02/24/15 05:46 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Same in this one.
Re: 63 max wedge oil pickup [Re: 62maxwgn] #1761099
02/24/15 05:55 PM
02/24/15 05:55 PM
California
mickm Offline OP
mickm  Offline OP
California
great, that's what we'll do. thanks!
Re: 63 max wedge oil pickup [Re: mickm] #1761100
02/25/15 08:40 AM
02/25/15 08:40 AM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
You might also want to check Mopar Performance #P5249817 pickup mentioned here -> http://racehemi.maxwedge.com/topics/oilpans.php ?
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: 63 max wedge oil pickup [Re: mickm] #1761101
02/26/15 01:40 AM
02/26/15 01:40 AM
When I was racing my 1963 M.W. car in NHRA stock I ended up using a 1966 to 1969 426 Street Hemi oil pan and pickup to help that motor live while drag racing it, it fits and works nicely
Re: 63 max wedge oil pickup [Re: Anselmi] #1761102
02/26/15 01:45 AM
02/26/15 01:45 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
..... pickup mentioned here -> http://racehemi.maxwedge.com/topics/oilpans.php ?
The swinging pickup shown on the link appears different than the one I posted.
Re: 63 max wedge oil pickup [Re: srt] #1761103
02/26/15 02:41 AM
02/26/15 02:41 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I'm working on a 64 MW and the original swinging pick-up looks like the one in the link not the one you've posted...Was there an change/upgrade after a certain timeframe ???{Other than the size increase}
Re: 63 max wedge oil pickup [Re: screamindriver] #1761104
02/26/15 10:33 AM
02/26/15 10:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All I've had were as you mentioned in link,not like the one the OP posted.
Re: 63 max wedge oil pickup [Re: 62maxwgn] #1761105
02/26/15 02:09 PM
02/26/15 02:09 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Interesting.
The one I posted was from a 413 mw w/ notched deck and cast date of 3-16-62
I wonder if it was an early design changed because of leakage?
