Battery Cover #1759648
02/21/15 03:23 PM
02/21/15 03:23 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hello. I would like to know does anyone know if they make a cover for a modern battery that looks like the original battery? Any sugestitons? Funds are tight. Its for my 1970 Plymouth GTX 440 6 pack which I've had in the garage for the last fifteen years.
Re: Battery Cover [Re: GTXKARL] #1759649
02/21/15 03:34 PM
02/21/15 03:34 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yes battery toppers are available for group 24 batteries not group 27 batteries. So what size do you have in your car? Remember it's only a topper so you probably will notice from the sides. If it was say a Buick it would be hard to notice because of how they are mounted .
Google Battery Toppers
Ron
Re: Battery Cover [Re: RJS] #1759650
02/21/15 05:36 PM
02/21/15 05:36 PM
CA
cudino Offline
cudino  Offline
CA
I think this car should get a Group 27 Battery. However, for tight funds you could use a Group 24 red-cap topper and corresponding parts-store battery and it would look OK. Not great but OK. You might have to trim a little off the topper to make room for the hold down, that's what I did, but it's not obvious unless you looked close.
- Wade
Re: Battery Cover [Re: cudino] #1759651
02/21/15 09:00 PM
02/21/15 09:00 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
If you could get the stickers off the side of the existing battery these would "kinda" work. Kinda like a $20 hooker with too much lipstick.
http://www.batterytoppers.com/products/
Re: Battery Cover [Re: Lefty] #1759652
02/22/15 08:33 PM
02/22/15 08:33 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
63.00 dollars for a fake piece of plastic when you can get the real thing for 225????No brainer for me.I use a battery tender on mine and they last 5-7 years...
Re: Battery Cover [Re: 70RR383] #1759653
02/24/15 02:28 AM
02/24/15 02:28 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Let's hope somebody picks up the manufacturing from turbostart or the resto battery market is going to get ugly... The topper is OK just be aware your battery hold-down might need modified because of the added width of the topper....
