Determining if an Engine is Original.... #1759372
02/20/15 09:38 PM
02/20/15 09:38 PM
Florida, US
72ls5fla Online content OP
72ls5fla  Online Content OP
Florida, US
Here is what I have...
1970 Challenger 440 Sixpack. build 0613
I am 90% sure the engine in my 70 440+6 challenger is original.
However, I have an anomaly that I have not seen before.
1. The casting number and date on the block seem correct for my build date.
2. The machined upper stamp pad has F440 HP and a stamped date of 0601,
the machine marks look very correct and 99% sure not been restamped.
now what is very weird.
The side pad is not been stamped with the VIN. It has the swirls that look very correct and thats it.
every other part on/in the engine compartment is date and part# correct.
Only parts that are reproduction are the coil and voltage regulator.
and they are dated/ink stamp correctly.
Is it possible that the engine got missed during the stamping process?
The 727 is stamped and original to the car.
I have just never seen this before. There are so many things correct on the car.
Opinions very welcomed.
FWIW... I was never told it to be original when I purchased the car. but the owner could not say either.
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Determining if an Engine is Original.... [Re: 72ls5fla] #1759373
02/20/15 09:50 PM
02/20/15 09:50 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
Does the pad have an S stamped on it?
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Determining if an Engine is Original.... [Re: vette1986] #1759374
02/20/15 09:52 PM
02/20/15 09:52 PM
Florida, US
Florida, US
upper or lower?
Re: Determining if an Engine is Original.... [Re: 72ls5fla] #1759375
02/20/15 09:53 PM
02/20/15 09:53 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
upper pad by dist
1969.5 A12 Bee EV2
1971 Charger RT
Re: Determining if an Engine is Original.... [Re: vette1986] #1759376
02/20/15 09:54 PM
02/20/15 09:54 PM
Florida, US
Florida, US
nope
just F440
HP and date
Re: Determining if an Engine is Original.... [Re: 72ls5fla] #1759377
02/20/15 09:56 PM
02/20/15 09:56 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
that would rule out a service block replacment but could still be an over the counter block someone stuck in it but with the date range on the casting where it needs to be for your car and the upper pad assembly date good too that would seem unlikely IMO. are there ANY faint stampings on the lower vin pad I have seen some that are very very faint.
1969.5 A12 Bee EV2
1971 Charger RT
Re: Determining if an Engine is Original.... [Re: vette1986] #1759378
02/20/15 09:59 PM
02/20/15 09:59 PM
Florida, US
Florida, US
i did a real through cleaning of the side pad and could not see anything at
all.
Re: Determining if an Engine is Original.... [Re: 72ls5fla] #1759379
02/20/15 10:01 PM
02/20/15 10:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Look close, all around the pad. Some stamps have been found on the block above the pad & some on the oil pan as well.
Re: Determining if an Engine is Original.... [Re: Alaskan_TA] #1759380
02/20/15 10:05 PM
02/20/15 10:05 PM
Florida, US
Florida, US
damn ..
Barry -
if it was on the oil pan I'm screwed. That got changed out with a NOS one
there was a dent on the bottom and I wanted it gone. Changed out while I had the engine out couple years back.
I did not see anything above the pad. but I also did not look all that hard.
I will get the car up on the lift and poke around some this weekend.
maybe I will get lucky. :-)
