rad. core support blacking and wheel wells #1758416
02/19/15 11:43 AM
02/19/15 11:43 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
I was curious, is there a thread on the blackening of the radiator core support for a '70 Cuda? Does it get behind the headlamp buckets and suck? I am helping a friend restore his '70 Hemi Cuda and he's not too much into computers. Also, is there an application illustration for the undercoating treatment in the wheel wells ( front & rear ).
Thanks in advance...
Troy
Houston Mopar Connection Club
Re: rad. core support blacking and wheel wells [Re: hemi68charger] #1758417
02/19/15 12:00 PM
02/19/15 12:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
There is a factory diagram for the rad support.
But for rad support black and wheel well undercoating, I'd go off original examples. I know there was an old thread on E-body rad support backout showing examples of how deep into the headlight bucket area. There's variation.
On wheel well's I remember threads with dave walden and troy bray showing example and what they did.
I have 71 challenger fenders that are totally covered behind the bucket and inside corners.
Re: rad. core support blacking and wheel wells [Re: hemi68charger] #1758418
02/19/15 01:03 PM
02/19/15 01:03 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Was the rad core support blacked out from the factory? Some cars got over looked on that.
Re: rad. core support blacking and wheel wells [Re: 71birdJ68] #1758419
02/19/15 01:15 PM
02/19/15 01:15 PM
Houston, Tx
Houston, Tx
This car has had many paint jobs over the lifespan of it. My buddy raced it for decades.... it is only now he's restoring it back to OEM correctness. So, all the original treatment is gone......
Troy
Re: rad. core support blacking and wheel wells [Re: hemi68charger] #1758420
02/19/15 01:41 PM
02/19/15 01:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Use it as a guide,,not a blueprint.
Re: rad. core support blacking and wheel wells [Re: gtx6970] #1758421
02/19/15 01:57 PM
02/19/15 01:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Over spray is also normal, the cars were not masked.
Re: rad. core support blacking and wheel wells [Re: Alaskan_TA] #1758422
02/19/15 02:16 PM
02/19/15 02:16 PM
Houston, Tx
Houston, Tx
Thanks Bill and Barry....
Any info on the rear wheel well? I'm taking it the shaded section on the wheel well and wheel-side fender apron are also spray..
Troy
Re: rad. core support blacking and wheel wells [Re: Alaskan_TA] #1758423
02/19/15 02:23 PM
02/19/15 02:23 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
the blackout on my 70 Challenger (build Sept69) covers very little of the headlight area
Re: rad. core support blacking and wheel wells [Re: 70BigBlockSE] #1758424
02/19/15 02:27 PM
02/19/15 02:27 PM
Houston, Tx
Houston, Tx
Anything unique for a '70 Cuda in this regard?
Troy
Re: rad. core support blacking and wheel wells [Re: hemi68charger] #1758425
02/20/15 12:39 PM
02/20/15 12:39 PM
Houston, Tx
Houston, Tx
Any Cuda wheel well black undercoating pictures?
Troy
Re: rad. core support blacking and wheel wells [Re: hemi68charger] #1758426
02/20/15 12:53 PM
02/20/15 12:53 PM
the Netherlands
Mr4Speed Offline
Mr4Speed  Offline
the Netherlands
T,
I have got some pics of Dave Walden's 70 Chally; those pics will help.
I can e-mail them tomorrow if you like.
Best regards, Marcel
Re: rad. core support blacking and wheel wells [Re: Mr4Speed] #1758427
02/20/15 02:31 PM
02/20/15 02:31 PM
Houston, Tx
Houston, Tx
T,
Thanks Marcel.... Let me do another search for that thread within moparts.
Troy
Re: rad. core support blacking and wheel wells [Re: hemi68charger] #1758428
02/21/15 03:01 AM
02/21/15 03:01 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Here's the only pic I had taken of my '70 Barracuda's rh/pass side, don't have one at all for the lh/driver's.
Can basically see how the firewall area was loaded with undercoating, and traces under the diagonal brace.
While the control arm area and inspection plate see a mask pattern, there were traces of undercoating oversprayed onto each upper arm.
Way to go on getting the ole 426 hemi running, good for you, Troy, hope you have lottttts of fun times & many miles with it, and may all that good work from the past keep you confident for this future resto on the 'Hemi Cuda.
Re: rad. core support blacking and wheel wells [Re: ebodyseast] #1758429
02/21/15 05:23 AM
02/21/15 05:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's another 70 challenger. Between the headlights on this one particular car.
this car has been repainted o the outside and there's overspray on bumper brackets obviously.
Re: rad. core support blacking and wheel wells [Re: autoxcuda] #1758430
02/21/15 05:24 AM
02/21/15 05:24 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
drivers
Re: rad. core support blacking and wheel wells [Re: autoxcuda] #1758431
02/21/15 05:25 AM
02/21/15 05:25 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
core support
Re: rad. core support blacking and wheel wells [Re: autoxcuda] #1758432
02/21/15 05:58 AM
02/21/15 05:58 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's some in progress pictures from the big thread on Dave Walden's White on blue 70 Challenger
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Made templates off original patterns:
Driver's front
Passenger front
Passenger rear
Before passenger front
Re: rad. core support blacking and wheel wells [Re: autoxcuda] #1758433
02/21/15 06:11 AM
02/21/15 06:11 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Found some very good pictures of a 70 Cuda radiator support and headlight blackout.
https://board.moparts.org/ubbthreads/show...rue#Post6858306
Re: rad. core support blacking and wheel wells [Re: autoxcuda] #1758434
02/21/15 11:39 AM
02/21/15 11:39 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Troy the rocker pinchweld sould be blacked out as well and I think they used a brush for that.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: rad. core support blacking and wheel wells [Re: mopargem] #1758435
02/21/15 12:59 PM
02/21/15 12:59 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Heres a few pics from the front of my 70 AAR, thought the yellow contrast makes it easier to understand than some other colors.
