Carb wont hold an idle. Dirty jets?
#1757748
02/18/15 04:31 AM
02/18/15 04:31 AM
Posts: 624 Modesto CA
BFASTER
Modesto CA
Its a Holley 80508 4 bbl that after start up begins a steady decrease in idle speed until it dies. Takes about a minute or so to finally stop running. Idles great for about 10 seconds, then...... Even if I feather the throttle to keep it running until it starts warming up it will die. Float?
1969 Dodge Super Bee Hardtop
2007 Nissan Altima 3.5SE
Re: Carb wont hold an idle. Dirty jets?
[Re: Kern Dog]
#1757750
02/18/15 07:07 AM
02/18/15 07:07 AM
BFASTER
Modesto CA
No...no pressure gauge. And the pushrod is new, less than 800 miles on engine/fuel pump.
[Re: BFASTER]
#1757751
02/18/15 12:28 PM
02/18/15 12:28 PM
Posts: 12,075 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Has this combo idled okay before for you and just now started dying at isle? Or is it new to you with no previous experience with it?
A few things to check; vacuum leak, initial timing, fuel delivery, dirty fuel, bad PCV valve, proper idle jet, proper idle air bleed, proper float level.
Master, again and still
[Re: DaveRS23]
#1757753
02/18/15 12:38 PM
02/18/15 12:38 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I like most others also always blame the carb... Last time I had near the same issue it was the plate in the distributor not returning correctly...A little spray of WD and it was gone... Like a dumma$$ I mentioned it to my engine builder...He said "I wish I could find a way to lock up the carburator in the trunk...as soon as something's not right everybody wants to mess with the carb."
...FAFO...
[Re: skicker]
#1757754
02/18/15 12:59 PM
02/18/15 12:59 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Does it smell heavy rich? My first though is float level or needle and seat not closing properly causing a loading up situation. I take it that if you clear it out the cycle will start all over again?
Careful, your character's showing!
[Re: mopar346]
#1757755
02/18/15 01:22 PM
02/18/15 01:22 PM
RapidRobert
count # of turns to get the 2 idle mixture screws in to lightly seated. Take out the idle mixture screws. shoot a 3 second blast of starting fluid into each of the two ports with ae thin red straw (likely have to work the nozzle so a straw will fit as SF cans do not usually come with/use a straw). replace mix screws to orig # of turns. See if it will now idle
