Re: 71 340 shaker cuda negative battery cable question.
[Re: 71redcuda]
#1756220
02/17/15 03:12 PM
02/17/15 03:12 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
WARNING - not an original unmolested engine ..... but
Cable-end connects on the backside of shaker brackets in the hole mentioned above. Brackets i have seen is bare metal on backside.
THANKS Nicklas
Made more sense that way since a foot bracket would have to be removed before a neg cable which could be just as easily disconnected at battery end. Those feet brackets were the first thing a mechanic tossed when having to work on an engine, carb ,etc, told to me by a mechanic from back in the day who said he couldn't stand the things sticking up and getting caught on sleeves, etc.
[Re: mccannix]
#1756221
02/17/15 03:39 PM
02/17/15 03:39 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Not sure I'm following? It wouldn't make sense for the negative battery cable to be between the head & SHAKER foot bracket, the lug on the cable end wouldn't sit flat/square & a good ground/tight fastener isn't going to happen. Do both bolt heads for the air cleaner base plate "L" brackets face forward?
