Re: Fuel System Upgrade Recommendations
[Re: Benforsp]
#1755794
02/16/15 02:17 PM
02/16/15 02:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would suggest a 3/8" min supply and the same for the return.. if your going with EFI it will need a good return.. I myself run a 1/2" supply and return with my set up.. it was carbed but now I run a Holley multi point EFI and the system is good up to 700 hp.. if I were to go more than that I would need a bigger pump and injectors.. the rest will work... the issue with a 3/8 line that I dont like is the bends.. if you get any kink at all it reduces the flow... the ID is already 5/16" on a 3/8" EDIT Also... if you keep the stock tank I would add a sump to it... injection doesnt like to have air sucked in and if you run low in the tank it will suck air in ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1755795
02/16/15 05:00 PM
02/16/15 05:00 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
Bigger is better when it comes to fuel line sizes, my next race car will have a 5/8 O.D. fuel ine with a 1/2 minumim return line, that is Carbureted, not EFI I'll put on what ever size the fuel stystem, probally Magnafuel, company recommends ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Benforsp]
#1755797
02/16/15 07:44 PM
02/16/15 07:44 PM
MR_P_BODY
Seems as though bigger is better as you never know where you will end up. I have noticed there are more hose choices available these days that still meet the track rules. You are not required to buy these stainless braid anymore. Any experience with the push-lock hose? Seems priced right and would think it would be easy to work with? The price difference between -8 and -10 is pretty minimal...Not sure if it is compliant with the new fuels though?
I havent used any push lock but I do use the black braided hose with alum fittings... if you run a hose that has a Viton liner its good for any fuel... I use the standard black braided and its good for pump gas since thats what I run which can have 10% ethanol ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Cab_Burge]
#1755801
02/17/15 01:26 AM
02/17/15 01:26 AM
MR_P_BODY
I used the steel lines (3/8 supply, 5/16 return)EFI pumps do not like to suck.
I don't think any electric fuel pumps like to suck, they push better than suck usually.
Pumps dont suck.. they create the negative pressure so atmospheric pressure can push in the fuel(or oil like in a oil pump) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1755802
02/17/15 04:05 PM
02/17/15 04:05 PM
Posts: 153 Bradenton, FL
Benforsp
Bradenton, FL
So while its in its carb version am I going to be able to pull the fuel out of the tank using the stock pickup.
[Re: Benforsp]
#1755803
02/17/15 04:12 PM
02/17/15 04:12 PM
MR_P_BODY
Yes but if your running more power than stock a larger pick up would be nice(depending on whats there now) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1755804
02/17/15 10:06 PM
02/17/15 10:06 PM
Posts: 7,664 IN
ahy
IN
Moderate size carb electric pumps seem to handle the stock pickup OK... many members have good luck. As posted above, a bigger pickup is better. 3/8" minimum, 1/2" preferred. Somebody with more experience will likely post good combos.
EFI pumps just don't work very well or long with the restriction of the stock style pickup. I toasted a couple as have others before going to pump in tank (or sump). Fuel system upgrade for EFI can get involved so maybe best to pick a pump to cover the carb for now and deal with the EFI requirements later.
[Re: ahy]
#1755805
02/17/15 10:20 PM
02/17/15 10:20 PM
Benforsp
Bradenton, FL
That is the plan...the carb pump will be something to get me by and will definetly go with an in tank solution for EFI (Phantom Maybe?) but I would like the lines and anything I can put on it to be compatible so I don't have to duplicate anything. That's why I want the line sizing correct etc. The current pickup is a replacement and it's 3/8". I just want to make sure it will do for now. All the suggestions are great. I have flirted with E-85 as it is coming to this area slowly so I am really only looking to minimize any possible "redo" work. Hopefully, the push lock stuff will work and a simple pump for now.
[Re: ahy]
#1755808
02/18/15 12:35 PM
02/18/15 12:35 PM
Benforsp
Bradenton, FL
The stock replacement steel lines (3/8" supply, 5/16" return) work great on the pressure side of my EFI setup. Mine is a ~550 HP 496 with pump rated for 700 HP. Would probably work fine with higher HP as long as the pump has an un-restricted feed (pump in tank or sump with -10 lines or bigger feeding the high pressure pump inlet).
My concern is I have the smaller lines and didn't think they would be sufficient. I figured I would need to upgrade and looking at the cost of the prebent stainless lines they are about the same cost as going with larger push-lock or stainless braid. I figured why not upgrade for the future?
[Re: Benforsp]
#1755809
02/18/15 01:10 PM
02/18/15 01:10 PM
Posts: 1,178 Indy
FlyFish
Indy
I have 1/2" push lock hose on my car from regulator to carb and it works great (1/2" hard line from cell to regulator). It is a bit of a pain to "push" the fittings into the hose, but after the trial and error approach, I found that putting the end of the hose in boiling water for 15-30 seconds then jamming it on the fitting worked best.
My car is on e85 if that helps.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1755810
02/18/15 03:06 PM
02/18/15 03:06 PM
Benforsp
Bradenton, FL
Flyfish,
What brand are you using for push-lock hose? Do they give you any trouble at the track?
