E85 1250 CFM Dominator #1755328
02/15/15 10:07 PM
02/15/15 10:07 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Has anybody every converted a Holley 1250 Dominator gas carb over to E85? If so, what were your results and any pointer would help. Going on a 540cid (4.28" bore X 4.50"stroke) 12.3:1 comp with Indy -1 heads and about a .680 lift roller.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: E85 1250 CFM Dominator [Re: 65 Hemi] #1755329
02/15/15 10:19 PM
02/15/15 10:19 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Yes I have used quick fuel kit car slowed down from 9.75 to 9.82 mph dropped off about 3.5 mph.(on 572 with 12.3 comp.) save yourself some grief send it to mark sullens..... have not tried it yet. the transition slot is much to narrow per mark also the boosters in the kit were to large for my combination. and also it was converted to a two circuit.pat
Re: E85 1250 CFM Dominator [Re: pattyboy 572] #1755330
02/16/15 01:46 AM
02/16/15 01:46 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Mark Sullens is the man, waiting on dyno results of his 1050 on my 512.
He might think the 1250 is too big, I was worried about a 1050 on my 512 at 13:1 and 750+ lifts..
Re: E85 1250 CFM Dominator [Re: mopartony] #1755331
02/16/15 12:27 PM
02/16/15 12:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The 1250 carbs have a REALLY big throttle blade and tend to not work well on many motors. Just sharing my experience from what we have seem on other combos.
Re: E85 1250 CFM Dominator [Re: Al_Alguire] #1755332
02/16/15 01:18 PM
02/16/15 01:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly...........weaker signal in the wrong application for starters.
Re: E85 1250 CFM Dominator [Re: Thumperdart] #1755333
02/16/15 02:19 PM
02/16/15 02:19 PM
new york usa
P
P
new york usa
That exactly why mark installed the smaller boosters to increase signal strength.also due the increased viscosity of e-85.the other fact as mentioned earlier was the transition slot. pat
Re: E85 1250 CFM Dominator [Re: 65 Hemi] #1755334
02/16/15 05:07 PM
02/16/15 05:07 PM
Try contacting AJ Casini on here for your conversion, I had him do a E 85 1150CFM HP Holley Dominator for me several years back, it works well It is on my 505 C.I,.400 block bracket motor, 4.350 bore with 4.250 stroke, it has ran a best of 9.003 at 147.7 MPH in my 2780 lb 1970 Cuda bracket car Hopefully I can tune it to run 8.90 at or above 150 MPH this year, I raced it on the throttle stop most of last year due to not having NHRA Comp. racing drivers license and safety gear until mid August of last year
Re: E85 1250 CFM Dominator [Re: Cab_Burge] #1755335
02/16/15 05:31 PM
02/16/15 05:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well Cab if ya need a driver I know a guy
Re: E85 1250 CFM Dominator [Re: Al_Alguire] #1755336
02/16/15 08:30 PM
02/16/15 08:30 PM
Not now, I bought the required gear and renew the old license I'm debating on to try traing my middle grandson or not He's the only one of the three that is interested in any kind of car or motorcylce racing. Same way with my daughter and son, they never wanted to drive the drag cars, they both loved riding two, three and four wheelers in the desert though, especaiily Dumont dunes The wife would drive my old stocker at George Air Force base on thier old 1/8 mile track but not on any 1/4 mile tracks, she said the car was to fast in the 1/4 It would run 95 MPH in the 1/8 and 117 in the 1/4 mile Now if you know someone who can retrain a old guy like me so they can win more than one or two rounds at each race I'm in
Re: E85 1250 CFM Dominator [Re: 65 Hemi] #1755337
02/16/15 09:53 PM
02/16/15 09:53 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I did, sent it to APD and loved it. When I got to 16-1 compression, I sold it.
Re: E85 1250 CFM Dominator [Re: pattyboy 572] #1755338
02/17/15 12:50 AM
02/17/15 12:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Then it`s no longer a 1250............
Re: E85 1250 CFM Dominator [Re: Cab_Burge] #1755339
02/17/15 02:04 AM
02/17/15 02:04 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Cab.....do you remember what jets were in there?
Re: E85 1250 CFM Dominator [Re: racerx] #1755340
02/17/15 04:57 AM
02/17/15 04:57 AM
It came with 93 in the front with a power valve and 103 in the back.He did change the metering plates and put in a set of Dominator annular boosters with the flared skirts, probally doesn't flow 1150 anymore It does work very well, repeats like it is dead on
Re: E85 1250 CFM Dominator [Re: Thumperdart] #1755341
02/17/15 10:03 AM
02/17/15 10:03 AM
new york usa
P
P
new york usa
Thumper, consulted lee on booster size ,he said smaller would result in a weight savings.....LOL....
Re: E85 1250 CFM Dominator [Re: pattyboy 572] #1755342
02/17/15 01:16 PM
02/17/15 01:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As I said before most of those OOTB Holley, QF 1250's have way to big a throttle blade/bore for probably 99% of the cars out there. Certainly from this board. Just been what I have seen. I think you will find plenty of them out there for sale and likely there is a reason.
Re: E85 1250 CFM Dominator [Re: Al_Alguire] #1755343
02/17/15 01:43 PM
02/17/15 01:43 PM
new york usa
P
P
new york usa
Al ,ran with c12 vp and an 1150 cfm Holley,bolted on 1250 gen ootb,the car picked up a tenth and 3.5 mph ,my down fall was attempting to switch to e-85 with the 1250 i would have been better off converting the 1150 to e-85 than the 1250.just a few short months till we see marks results...pat
Re: E85 1250 CFM Dominator [Re: pattyboy 572] #1755344
02/17/15 01:58 PM
02/17/15 01:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not saying it aint for all just aint for most is all My carb is a good deal bigger CFM wise but with a more favorable blade booster sizing. Looking like my pair for the Predator will flow more cfm than 1250 as well.
IMO if it picked up that much over the 1150 it likely needed some more work, would be my opinion anytime an OOTB carb picks up from a previous carb of that size that was dialed in unless it was simply the worng carb to begin with. A tenth and 3.5MPH is a TON. Just sayin.
Re: E85 1250 CFM Dominator [Re: Al_Alguire] #1755345
02/17/15 05:21 PM
02/17/15 05:21 PM
new york usa
P
P
new york usa
Al , you r 100% correct ,after three outings with the 1150, i replaced it with the 1250,had i spent more time with the 1150 i very well would have achieved the same result,(or better)but the carb was a gift and black looked good....then the e-85 deal came along pat
Re: E85 1250 CFM Dominator [Re: pattyboy 572] #1755346
02/17/15 05:41 PM
02/17/15 05:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hey I am not an expert by any means just trying to make an observation. I agree those black carbs look awesome!! We have played with E85 a bit, have a built carb for it. Still faster with Q so we always go back. I have the carb and over a half full drum of E85 I need to sell.
Re: E85 1250 CFM Dominator [Re: 65 Hemi] #1755347
02/17/15 06:03 PM
02/17/15 06:03 PM
an8sec70cuda Offline
FWIW...I have a Pro Systems 1150 based 1200 cfm Dominator on my 572" Hemi. I contacted them a few years ago to see about converting it over to E-85...they said they'd want to start w/ a 1250 main body. Something about the added volume of fuel, they'd want the bigger carb body and extra air flow. At that point it made more sense to just buy the E-85 carb complete than to have my good working carb converted...didn't want to spend that much at the time, so I never went ahead w/ it.
CHIP
'06 GMC 2500HD LBZ Duramax
