Re: Starting problems 71 Challenger
[Re: rumblebee4232]
#1753917
02/16/15 04:39 PM
02/16/15 04:39 PM
Posts: 512 Niwot, CO Formerly denn...
dynorad
There are two circuits involved here. One is a "low current" that goes through the ignition switch. The other is a high current that passes through the starter relay/solenoid. Have a helper test the voltage at the terminal from the ignition switch while you try to start. The most likely culprit is a low battery, followed by the switch or the bulkead connector. If that voltage is fine, have your helper test the battery voltage while you are cranking. If the battery voltage is fine, check the voltage on the terminals also while cranking. If good test the starter terminal while cranking. If the voltage is good at the starter terminal replace the starter or the starter solenoid. Also ensure that your ground from engine to battery is good and that you have the engine grounded properly to the body.
[Re: dynorad]
#1753918
02/16/15 05:08 PM
02/16/15 05:08 PM
Posts: 1,584 MD
p d'ro
MD
Can he jump the solenoid like I used to on my GM? Good old screwdriver touching terminals together?
[Re: p d'ro]
#1753919
02/16/15 05:39 PM
02/16/15 05:39 PM
Posts: 21 New Zealand
Wiggy
New Zealand
Jumping the terminals sounds exciting I guess with the 12v going to the large terminal on the starter being constant and the smaller terminal being just in front, it would be easy to bridge the two with a screwdriver. This I guess bypasses the starter relay? If you read up a bit, I did test the starter (both terminals) during ignition and the main 12v feed dropped slightly and the smaller one that has nothing going to it to start with got around 11.5v when the key is turned. This to me suggests the electrics are working ok, I've checked the grounds, I even installed a second battery to body ground and I might add another engine to body ground as well (can't have too many grounds...hehe). I think the starter is at fault here, the fact that it jumps out but doesn't engage the flywheel wheel means its kinda working but just not energizing properly? The annoying thing is, I've had the car for over 3 years and its always cranked over, up until the back end of last year anyway. I had this problem once before where it just clicked but the next time I tried, it turned over. This time however, nothing and I've been trying and trying hoping it would just go. I plan to remove the starter this week, I will bench test then to see what happens.
[Re: Wiggy]
#1753920
02/16/15 06:31 PM
02/16/15 06:31 PM
Posts: 4,848 Memphis
HemiRick
Memphis
If the bendix is jumping out and the starter is not turning the contacts in the solenoid are not working.....time for a starter or new contacts....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: skicker]
#1753922
02/16/15 07:21 PM
02/16/15 07:21 PM
Wiggy
New Zealand
If you have narrowed it down to the starter do yourself a favor and hit the starter a few times with a BFH. I've had them turn over and work for months after that. If it doesn't work oh well your going to swap it out anyway.
Yeah sadly I've tried the hitting it method from above and below, while my wife turned the key to try and help it but zip I'll remove and check it out, the starter looks new so maybe its just because it's been sat not doing much for a few years while I restored it?
[Re: Wiggy]
#1753923
02/17/15 08:06 PM
02/17/15 08:06 PM
dynorad
What is the voltage between the big terminal on the starter and battery negative post while cranking? Then check voltage from the big terminal to the engine block while cranking and let us know what the voltage is.
[Re: dynorad]
#1753924
02/20/15 12:10 AM
02/20/15 12:10 AM
Wiggy
New Zealand
Missed that last comment and went and removed it from the car after a lot of swearing trying to get it round the exhaust header. Anyway, bench test revealed it still doesn't work!! It just clicks as it did on the car, kinda jumps out a bit but goes right back in, no spinning like it should. The annoying thing is, the starter looks new, I stripped the solenoid to check the brushes and they look fine, all the inside looks OK. Is there anything in particular I should check on the inside of the starter or solenoid? As previously mentioned the car was part restored when I got it, which probably explains the almost new looking starter but if this was an aftermarket replacement perhaps its not up to the standard of the original? I tested by fixing the negative terminal on the battery to the body of the starter via a battery cable and then the positive from the battery going to both small and large terminals, all I get it click click and a few small arc sparks from the battery as I touch it on. Clueless
[Re: Wiggy]
#1753926
02/20/15 12:16 AM
02/20/15 12:16 AM
RapidRobert
Open it up further. The solenoid ain't moving far enough for the large terminal to get continuity to the armature for the whole shebang to engage. Go further/you'll see what's fubared. EDIT If you're in a rush, what Skicker said, toss another one (reg or mini) in there & be up & running. plenty of parts over there?
[Re: Wiggy]
#1753931
02/20/15 04:32 AM
02/20/15 04:32 AM
Wiggy
New Zealand
quick movie showing what happens Push solenoid down manually, motor spins up no probs. Join contacts of two terminals and the solenoid activates and pulls down the center tube, which connects the copper washer but the motor doesn't spin up? Confused??? https://www.youtube.com/watch?v=1R0hkdkCa4k
[Re: Wiggy]
#1753932
02/20/15 04:51 AM
02/20/15 04:51 AM
HemiRick
Memphis
Cant see movie it's private it says
Your symptoms indicate no contact across the round copper washer and 2 contacts on either side.....Are the surfaces clean?
