Page 4 of 4 1 2 3 4
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753613
03/03/15 01:30 AM
03/03/15 01:30 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Updated Spreadsheet with the 10 degree stuff:
Thanks for posting your findings
Heck yeah. Thanks for sharing your build as well. I'm looking forward to coming down and doing some stick shift racing with you guys.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753614
03/03/15 01:30 AM
03/03/15 01:30 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
"time will tell how everything holds up."
You said it right there.
Doug
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: jlatessa] #1753615
03/03/15 01:34 AM
03/03/15 01:34 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I see on Hughs' installation instructions, they address the shim
problem with instructions to trim the ends to avoid undue side
stress on the rocker pedestals.
Shims to my feelings are problematic because of the way we're introducing something into the original design that is
possibly degrading it.
My
Joe
Agreed 100% on the shims. I don't want to have to keep track of and clean all of that stuff every time the valve train comes apart either. The spacers on the other hand are a nice clean solution to a tricky and difficult to correct problem.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753616
03/03/15 07:37 PM
03/03/15 07:37 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The bolts I used were from McMaster Carr:
http://www.mcmaster.com/#90281a636/=w52oaz
http://www.mcmaster.com/#90281a638/=w52obb
Just for comparison, I noticed the strength rating on those studs are only 125,000 psi vs. what Hughes sells (I know, those are too short) that are rated at 170,000 psi.
Don't know what ARP's studs are, but I'd be curious if that 125,000 psi level is strong enough, considering the spring pressure you're going to run.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: BradH] #1753617
03/03/15 09:55 PM
03/03/15 09:55 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I was wondering the same thing, in fact I made a thread about it. Nobody really has any insight either way so I figured somebody has to figure this out. I guess it's going to be me?
http://www.americanfastener.com/astm-sae-and-iso-grade-markings-for-steel-fasteners/
The aluminum threads will pull out long before the stud breaks if you think about it. The studs have a flat for a wrench in the middle so they are not even full radius in the middle. Oh well that's what we are using.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753618
03/04/15 03:40 PM
03/04/15 03:40 PM
BradH Offline
BradH  Offline
I'd rather not...
Found the ARPs are 180,000 psi.
Not sure what the Indy studs are rated, but the longer of the two used in their 440-1/SR stud kits are 3.5+" long. If you were concerned enough to swap 'em out, you could probably get all long ones and cut down the ones that need to be shorter, 'cuz I believe their short ones are still < 3".
Just a thought (or two).
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: BradH] #1753619
03/05/15 01:21 PM
03/05/15 01:21 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I'd rather not...
You are correct on the Indy studs. I am going to measure up the Hughes, Indy, and Jeremiah (McMaster-Carr) kit over the weekend and post the lengths. To set this straight my concern is only the center rocker stand due to it's lack of girth and problems experienced by other users.
So yes, the 3.5" studs are not a concern. My initial measurements told me that I needed a 3" stud with 1" of thread engagement into the center rocker stand. As far as I know there is only one made and having them made up custom at $22/pc is out of the question. The studs from McMaster-Carr are high quality, rolled threads. The studs from Indy look like the thread was machined. Does anyone know the tensile strength of the Indy stud? What material do they use? Do we know what tensile strength is even required?
I sure don't have enough FEA, strengths of materials or load testing experience/background to say one way or another. I do have (barely) enough experience to say we are over thinking this and I should just run them and whoop some some a$$ on the street and track.
Look at it this way - if my engine breaks because of the studs or any other of the untested parts in it we can all learn and...I have another identical 511" short block sitting next to this one.
Besides, pretty soon it's going to get hot the only car we have running is the convertible. I'll forget about this nonsense, close the shop for summer and you can find us in the pond floating around with a cold beers.
bikini clad girl > sweaty meats heads at race track
ps Do any of you guys have the ability to test bolt shear at work? I'd be willing to donate some parts.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753620
03/05/15 01:54 PM
03/05/15 01:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What length heli-coil is in the center stand?
I replaced the center one with a 3/4" Time-sert, but that was after milling the stands down to use the max-wedge type blocks.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753621
03/05/15 02:07 PM
03/05/15 02:07 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
It's about 1"
I am also not using any shim stock on the rocker stands.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: BradH] #1753622
03/05/15 02:46 PM
03/05/15 02:46 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Just doing some math says these bolts will have a failure point of about 13800lbs, now assume 4:1 design margin and you have about 3450lbs working load limit. Back of napkin type math, but it gives an idea. S/F.....Ken M
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753623
03/05/15 04:08 PM
03/05/15 04:08 PM
BradH Offline
BradH  Offline
I put in 3/4" Heli-Coils in my center stands by drilling the original holes deeper below the surface of the main pedastals.
What I pulled out from Edelbrock looked more like 1" long, but even the 3/4" have twice the length vs. diameter of the studs being used.
If the center stands still break off at the surface, the Heli-Coil threads will (should?) still be there below it. But I really hope moving the thread engagement below the rocker pedestal and running the longer #2/4-type threads alleviates this concern.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: BradH] #1753624
03/06/15 04:51 AM
03/06/15 04:51 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It sounds like Edelbrock has made some changes from the early set I have. I haven't looked at the length of the inserts in the new heads.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753625
03/06/15 05:22 AM
03/06/15 05:22 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I drilled/tapped and installed new 1" thread inserts further in to head so that ALL of the threads are below the base of the stand. I believe the arp stud I used only has .750" thread length
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753626
03/06/15 01:19 PM
03/06/15 01:19 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
My notes tell me that my heads have about .300 of helicoil below the milled part of the pedestal.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753627
03/13/15 04:00 AM
03/13/15 04:00 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I took my heads to my cylinder head guy today and I noticed that the new version of MW Victors looks like the valve cover rail is raised more than my old castings. When we measured the old to new castings, the new ones appear to be about 0.100" taller? The reason it looked different was because we were looking at how the rocker stands were milled off for the max wedge rocker shaft blocks.
We looked at some valve spring options and longer valve options. He is going to check with PAC to see if they may have a spring that could work that is not listed in their catalog. He was also going to check the cost of custom length valves. The slightly longer valves and raised rocker shaft does move the rocker arm roller towards the outer/exhaust side of the valve tip, bit the pattern is not too bad.
He does have some PAC-1326 springs that I could get a good discount on.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1828974
05/18/15 04:20 AM
05/18/15 04:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Update. I was wrong on the valve cover rail. Measured both and they are the same. PAC valve springs set up up with thinner (I think 0.030" thick) spring locator seats, and +0.100" (I think, I did not measure them) Ti retainers. Used the stock Edelbrock valves and the PAC 1326 valve springs. I think we are around 1.950" to 2.000" install height according to the cylinder head guy I went to.
We milled the rocker stands and are using the MaxWedge type rocker shaft stands. Installed 3/4" long timesert thread inserts for the center stand, and using studs to attach the rocker shaft. Just ordered 3/8"x0.145" wall pushrods, 9.080" exhaust, 9.138" intake length from Smith Brothers.
That was all I needed to finish the engine.
Page 4 of 4 1 2 3 4
