Wheels and tires for a do it all corner carver
#1751008
02/10/15 02:47 PM
02/10/15 02:47 PM
Posts: 751 Saint Peters, MO
Brian
Saint Peters, MO
As many other have stated, the selection of wheels and tires for my 1971 Gen III Hemi Duster is extremely frustrating. I’ll be running 13” rotors up front with a HydroBoost master cylinder and have already purchased the Dr Diff 11.7” rear disc kit and 1/2" offset spring hangers and shackles for my 68-70 B-Body rear-ends. I’ll also be rolling the lips on the quarters and tops of the front fenders. I remember not too long ago how I was emphatic about not running “Steamrollers” on this car as my original plan was a 225/60-16 on black steelies with poverty caps! Trouble was all the maximum performance summer tires have moved into the 17” + diameter wheels and 17’s wider than 8” may hit the suspension and still require a 11.95” maximum sized rotor! Since I want to do it all in this car, drag, autocross, road race and Big Bend Open Road Race in west Texas next spring, probably in the Street Rod 95Mph class with my wife a copilot (That should be fun!) as well as drive the dang thing, I've decided to go with 18’s. My tire choice will be either Continental ExtremeContact DW’s or Michelin Pilot Super Sport. I’m still not sure if this will work, but here is what I have narrowed the selection down too: 245/40-18x9 +30mm 275/35-18x10 +45mm American Muscle satin black bullets http://www.rimsntires.com/specspro.j...r%20H2%20wheel245/40-18x8 +38mm 275/35-18x10 +42mm LateModelRestoration or OEWheels black Bullets http://www.rimsntires.com/specspro.j...r%20H2%20wheel255/40-18x9 +38mm square setup LateModelRestoration or OEWheels black Bullets 255/40-18x9 +38mm 285/35-18x10 +42mm LateModelRestoration or OEWheels black Bullets http://www.rimsntires.com/specspro.j...0Civic%20wheel
1971 6.1 Gen III Hemi Duster
Re: Wheels and tires for a do it all corner carver
[Re: Brian]
#1751009
02/10/15 02:56 PM
02/10/15 02:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Links don't work for me anyway. If you can find the weight, the lightest rim would be a good choice.
[Re: Brian]
#1751010
02/10/15 07:51 PM
02/10/15 07:51 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Skip the Contis. The Michelin is by far the better of the two.
[Re: AlexP]
#1751013
02/10/15 08:53 PM
02/10/15 08:53 PM
Posts: 369 Lubbock, TX
slantvaliant
Lubbock, TX
Can't help with tire choice, but it's always a treat to see classic Mopars at Big Bend. I'm a volunteer courseworker for the race, mainly because it's one of the best rolling car shows you'll ever see. Just look for the ragged white Valiant at one of the flag stations - that'll be me.
[Re: ahy]
#1751016
02/10/15 11:25 PM
02/10/15 11:25 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Your first wheel selection would be best IF your springs are moved in. With those wheels I would go 275 front and 285 or 295 rear.
Mopar to the bone!!!
[Re: Brian]
#1751017
02/10/15 11:42 PM
02/10/15 11:42 PM
Brian
Saint Peters, MO
I'm really looking for guidance with the tire size, wheel width and offset.
Will the +30mm or +38mm offset work upfront on the 9" rim on either the 245/40 or the 255/40 18's?
Will the +45mm or +42mm offset work in back with the 60.5" flange to flange (With the disc brakes) '68-70 B-Body rear-end in a Duster with the Dr Diff 1/2" offset spring hangers and shackles?
I prefer not to run spacers and I plan to have full size spare tire from the front that I can install with each combination.
The height on the 245/275 combination is (25.7"/25.6")
The height on the 255/285 combination is (26"/25.9")
I really don't want to go any wider than this.
[Re: Brian]
#1751019
02/11/15 12:11 AM
02/11/15 12:11 AM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
I tried both the 245/40 and 255/40 on +35mm 18"x9" for the front on mine, either was no issue. +38mm would work fine on mine also. I have the Dr Diff 13" "Brembo-style" front brakes w/ '73-'76 disc brake spindles. I am running the RT615K 255/40-18 which is 25.9" tall. I had to trim the wheel opening at the front to allow for some turn in clearance on my Barracuda. Not sure how your wheel openings differ.
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
[Re: 68cuda440]
#1751020
02/11/15 12:23 AM
02/11/15 12:23 AM
68cuda440
Plano, Texas
Different angle, ride height set, 255/40-18 front, 325/50-15 rear (was still waiting for the 18" rear tires to come in at the time). These are the 18x9 +35mm wheels. Had just finished the "rough" body work and had not started sanding yet.
Michael
[Re: dangina]
#1751023
02/12/15 07:00 PM
02/12/15 07:00 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Brian -- You've stated "do it all in this car, drag, autocross, road race and Big Bend Open Road Race"... realistically, you'll be comprimising for each type of event by using only one set of wheels/tires.... Eventually, consider getting different sets of wheels/tires ... as well as considering each class/club rules, etc.... so that you'll enjoy those events and your car to the most it has to offer. Then, setting up the car and suspension is another area to consider, per event, class/club rules, etc. Sounds to me that maybe you should consider having a different car for each type of event... In fact... I would like to do the same thing.. have a different designated car for every different type of event I'd like to participate in. Its only $$...
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Uhcoog1]
#1751024
03/08/15 01:16 AM
03/08/15 01:16 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I'll be running again this year in the duster - signed up for the 135 / 168 class. Hope to meet you in person this time. Let's make sure that happens.
I'm on the waiting list with my '67 Charger!
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
