70 roadruuer fuel sender #1749242
02/08/15 06:29 PM
02/08/15 06:29 PM
New Jersey
mikerrch Offline OP
mikerrch  Offline OP
New Jersey
anyone help me with removal of the fuel sender from the fuel tank. The service manual says to use a tool number c-3582 spanner wrench (whatever that is) can't get it loose. thanks.
Re: 70 roadruuer fuel sender [Re: mikerrch] #1749243
02/08/15 06:35 PM
02/08/15 06:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the last time I did it I used a flat headed screwdriver and an 'impact' adjustment.
Re: 70 roadruuer fuel sender [Re: mikemee1331] #1749244
02/08/15 06:41 PM
02/08/15 06:41 PM
New Jersey
mikerrch Offline OP
mikerrch  Offline OP
New Jersey
I tried the screw driver route seems to be bending the tab with no movement from the wring itself.
Re: 70 roadruuer fuel sender [Re: mikerrch] #1749245
02/08/15 06:54 PM
02/08/15 06:54 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I would say it's seized on there. soak it down with penetrating oil and give it a day.
a spanner wrench looks like this -
Re: 70 roadruuer fuel sender [Re: mikemee1331] #1749246
02/08/15 07:41 PM
02/08/15 07:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I just stumbled across the tool you were looking for
http://www.billrolikenterprises.com/proddetail.asp?prod=2004
Re: 70 roadruuer fuel sender [Re: mikemee1331] #1749247
02/08/15 09:23 PM
02/08/15 09:23 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Here's another, but cheaper...
sending unit tool
