Re: fan spacer; b engine with air cond
[Re: ebodyseast]
#1747516
02/06/15 01:37 AM
02/06/15 01:37 AM
Posts: 500 NoVa
ebodyseast
NoVa
Measured each of them - at approx. 1/16" thick.
My guess is that an 059 spacer gets installed between the fan hub and the 2863260 fan clutch...
Edit: The ac and non-ac water pump impellers have different part numbers, maybe this spacer makes up for any difference in length variation between the two? The same fan hub was used on all 1970-71 Mopar engines.
[Re: RoadRunnerJD]
#1747523
02/17/15 09:55 AM
02/17/15 09:55 AM
Posts: 601 Mass
charge70
Mass
I bought my 70 Charger R/T U-code w/A.C. back in 81.Completely unmolested at that time and it didn't have that spacer in front or behind the waterpump pulley.It almost looks like a shim to correct pulley misalignment for belt wear. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
