fan spacer; b engine with air cond #1747515
02/05/15 10:16 PM
02/05/15 10:16 PM
NoVa
E
ebodyseast Offline OP
E
NoVa
I have 2 of these fan spacers here, p/n 2003059 from 1970-71 parts catalog list of all fan spacers in pic - school me...
Re: fan spacer; b engine with air cond [Re: ebodyseast] #1747516
02/06/15 01:37 AM
02/06/15 01:37 AM
NoVa
E
E
NoVa
Measured each of them - at approx. 1/16" thick.
My guess is that an 059 spacer gets installed between the fan hub and the 2863260 fan clutch...
Edit: The ac and non-ac water pump impellers have different part numbers, maybe this spacer makes up for any difference in length variation between the two? The same fan hub was used on all 1970-71 Mopar engines.
Re: fan spacer; b engine with air cond [Re: ebodyseast] #1747517
02/06/15 12:34 PM
02/06/15 12:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not aware of any spacer ever on a B body with B/RB engines.
The fan cluch is bolted directly to the water pump .
Fan clutch difference between the 2, is one is viscous clutch ( non ac) and one is thermostatic (with ac )
Re: fan spacer; b engine with air cond [Re: gtx6970] #1747518
02/16/15 11:30 PM
02/16/15 11:30 PM
NoVa
E
E
NoVa
Can anybody confirm if this spacer was installed prior to 1970-71? Is it listed in the 1968-69 parts book, too?
The 1970-71 parts book lists as only installed on B/RB engines with air cond, fits all but A Body - which didn't have the B engine option for 1970.
Re: fan spacer; b engine with air cond [Re: ebodyseast] #1747519
02/17/15 12:07 AM
02/17/15 12:07 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it appears in the '68 Parts Catalog (April '68 revision) 383 440 with A/C all bodies with a footnote "* Indicates change or addition."
Re: fan spacer; b engine with air cond [Re: ebodyseast] #1747520
02/17/15 12:14 AM
02/17/15 12:14 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Never saw one of those before? My fan clutch on both my 69 340 A/C Barracuda and my A12 car bolt directly to the nose of the water pump
Re: fan spacer; b engine with air cond [Re: RoadRunnerJD] #1747521
02/17/15 01:16 AM
02/17/15 01:16 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a couple of them, always wondered what they came from.
JB Rhinehart, Realist
A-Body's RULE!
Re: fan spacer; b engine with air cond [Re: 6bblgt] #1747522
02/17/15 01:33 AM
02/17/15 01:33 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
My '68 Bee w/factory air has a 2658456 fan clutch and never had a spacer, built mid/late June '68.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: fan spacer; b engine with air cond [Re: RoadRunnerJD] #1747523
02/17/15 09:55 AM
02/17/15 09:55 AM
Mass
charge70 Offline
charge70  Offline
Mass
I bought my 70 Charger R/T U-code w/A.C. back in 81.Completely unmolested at that time and it didn't have that spacer in front or behind the waterpump pulley.It almost looks like a shim to correct pulley misalignment for belt wear. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
