spark plug choice for a 10:1 383 with a 292° hyd cam? #1747280
02/05/15 01:33 PM
02/05/15 01:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
what would you guys advice regarding spark plug choice for a 10:1 383 with a 292° hyd MP cam?
This is a street driven engine.
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747281
02/05/15 02:02 PM
02/05/15 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NGK #5...............
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: Thumperdart] #1747282
02/05/15 02:14 PM
02/05/15 02:14 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
cant find that on summit....can you please point me to it?
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747283
02/05/15 02:21 PM
02/05/15 02:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s the heat range(hot)but you need the stocking # I think so let me check.
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: Thumperdart] #1747284
02/05/15 02:26 PM
02/05/15 02:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747285
02/05/15 03:19 PM
02/05/15 03:19 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
What type of cylinder head? stock cast iron or aluminum?
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: Ray440] #1747286
02/05/15 05:10 PM
02/05/15 05:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
If stock iron eads I would use a Autolite 74 or 75, try the colder #74 first and see if it and your local gas get along If aluminum then I would try the Autolite # 65 or 85(I think the # 85 are the restior plugs in 3/4 long reach, it is the same plug used in the stock SB Mopar heads )
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: Cab_Burge] #1747287
02/05/15 05:47 PM
02/05/15 05:47 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
autolite 3924's for 3/4" reach. 85's are 3/8" reach.
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: lewtot184] #1747288
02/05/15 05:49 PM
02/05/15 05:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
yes, I forgot to point out these are stock cast itron heads---
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747289
02/05/15 05:58 PM
02/05/15 05:58 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
are RN12YC the same as RC12YC?
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: lewtot184] #1747290
02/05/15 06:08 PM
02/05/15 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the 3924 also for my SB which works on the
BB alum heads for anything in the 10 compression range
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747291
02/05/15 06:11 PM
02/05/15 06:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
N is 3/4" reach.. C is 3/8" reach
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: MR_P_BODY] #1747292
02/05/15 06:15 PM
02/05/15 06:15 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
which mopar heads need 3/4 reach and which need 3/8"??
im talking stock cast iron small and big block, Stock HEMI,
and also what about the stealth heads, and the edelbrock big block heads?
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747293
02/05/15 06:19 PM
02/05/15 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your stock iron heads use a 3/8" reach... all SB
and BB alum heads use a 3/4" reach
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: MR_P_BODY] #1747294
02/05/15 06:24 PM
02/05/15 06:24 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
stock big block iron 3/8"
stock small block iron 3/8"
stock HEMI ???? my aaftermarket alum heads use 3/4" not sure about stock cast iron? I guess also 3/4"?
Aluminum aftermarket Big Block 3/4"
Aluminum aftermarket small block 3/4"
is the above correct?
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747295
02/05/15 06:42 PM
02/05/15 06:42 PM
stock small block iron 3/8" Nope, all the stock L.A SB heads use 3/4 reach plugs
Nope, see the SB quote correction above, 426 Hemi uses 3/4 reach plugs also like the L.A. SB Mopars use
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747296
02/05/15 06:45 PM
02/05/15 06:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All my SB stuff has been 3/4" but the rest looks right
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: MR_P_BODY] #1747297
02/05/15 07:00 PM
02/05/15 07:00 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
ok! got it!!!
So what plugs for my stock irom head 383 with 10:_1 compression and 292° cam? street driven.
If you guys couldd point me to a link on summit if would be awesome!!! thanks!!
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747298
02/05/15 07:04 PM
02/05/15 07:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
ok! got it!!!
I'll let Cab answer that for ya.. he is a BB guy with
way more experience than me on the heat range for BB
Re: spark plug choice for a 10:1 383 with a 292° hyd cam? [Re: domingo] #1747299
02/05/15 08:15 PM
02/05/15 08:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
ok! got it!!!
try some autolite 85's and see how they burn. they're cheap, fairly easy to get.
