Will I Fry My Header Coating? #1747047
02/05/15 02:49 AM
02/05/15 02:49 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
As I was installing my TTi headers I hopped on the TTi website to see what torque specs were on the flange bolts. In the instuctions I saw an alarming bit. It basically said that I should run cast iron exhaust manifolds or an old pair of headers to break in a new engine because of the mixture problems and other conditions that create enough heat to burn the coating off around the header flange. My headers came with the ceramic coating that was pretty scratched up from storage and shipping. I cleaned and scuffed them and shot them again with ceramic coating.
Is there a way to preserve the coating? Something tells me I should have had these baked at a powder coating outfit before I put them on this engine. The engine is installed and I REALLY don't want to remove it...
I’m listening.
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747048
02/05/15 04:30 AM
02/05/15 04:30 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
If your breaking in a cam then your probably toast the coating. Roller cam should not be a problem.
The coating needs to go through a couple normal heat and cooling cycles to cure properly.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747049
02/05/15 08:31 AM
02/05/15 08:31 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Lindy,
I've fired off several fresh HEMI and B/RB motors with TTI headers in place having the brite finish TTI coating and experienced no issues with damage to the coatings, even in spots where I had to "tune" the tubes with a hammer/block for dimples for clearance and actually cracked the coating...TTI coatings are very tough, I'd just keep a watchful eye on then during break in, purchase a large high speed commercial fan from a local HD or Lowes to blast some air at the front of the car while running, helps also
Mike
Re: Will I Fry My Header Coating? [Re: DAYCLONA] #1747050
02/05/15 09:13 AM
02/05/15 09:13 AM
IF you have plenty of timing in the engine and do not run it with retarded total timing you will not hurt the coating no matter what engine or what cam
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747051
02/05/15 11:46 AM
02/05/15 11:46 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Do you have a temp gun? Although you will have a lot going on at start-up, it might be a good idea to monitor the tube and flange temp. If it starts to go high, just shut it down and give it a chance to cool.
Master, again and still
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747052
02/05/15 12:01 PM
02/05/15 12:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I fried a set of TTI headers on a 440 breaking in the cam. They were glowing cherry red and I didn't have the timing or mixture correct. It's tough to know right at first. This happened within 30-60 seconds of the motor starting.
Mine developed a crack in between the tubes in the middle from the overheat situation. I took it off and welded it up. Nothing I could do about the coating. Next time I will know better.
Look close you can see the crack.
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747053
02/05/15 12:12 PM
02/05/15 12:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have never had one set of headers turn red or get overly hot on any break in, I must be lucky. For the price of TTIs they should jump out of the box and self instal. That said keep an eye on them and use a big fan.
Coming soon!!!!
Re: Will I Fry My Header Coating? [Re: Challenger 1] #1747054
02/05/15 12:12 PM
02/05/15 12:12 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Hard to know where your timing and mixture will be on initial startup. You might get lucky and be fine, or you could hurt the coating.
I'm pretty sure all coated headers carry this disclaimer.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Will I Fry My Header Coating? [Re: wingman] #1747055
02/05/15 12:58 PM
02/05/15 12:58 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Doug's have the same disclaimer. It's happened to someone somewhere...they sent them back...hence the disclaimer. I've done two with no issues...Challenger 1 did his and got burned. (pun intended) It's a chance you take...
...FAFO...
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747056
02/05/15 01:09 PM
02/05/15 01:09 PM
Detroit, MI
CCPcoatings.com Offline
Detroit, MI
You lost me at having the headers "baked at a powder coating outfit". I'm not sure how that would help you since you're trying NOT to overheat the headers in the first place.
To answer your question, YES you will generally trash the bright ceramic coating if you're firing up a new motor that hasn't been tuned properly or if you dyno an engine. Too lean and too rich are BOTH BAD. It's unlikely you'll hurt the flanges but too lean will overheat the coating from the flange to mid primary. Too rich and it will overheat mid primary to collector. The headers below took about a minute or two to discolor when the engine was too lean.
It sounds like you need to take the headers off anyway since the coating arrived damaged. Why would you accept them?
Re: Will I Fry My Header Coating? [Re: DaveRS23] #1747057
02/05/15 01:18 PM
02/05/15 01:18 PM
Detroit, MI
Detroit, MI
That's not going to help much in that its not calibrated for the bright finish. So you'll be off between 150f and 300f to start. Secondly, by the time you see over 1100f it would be too late to correct it.....
If you refuse to take the headers off your best bet would be to aim some heavy duty shop fans directly at the headers to keep them as cool as possible.
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747058
02/05/15 02:56 PM
02/05/15 02:56 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Just have a timing light at the ready ... connected and the distributor bolt ready to be loosened as soon as it's running and get the timing to 35* advanced ...Have the mixture screws out 2 turns , breaking in the cam you'll be off the idle circuit anyway and if your gas is 10% ethanol make sure to bump the primary jets up 2 or 3 sizes. .
Re: Will I Fry My Header Coating? [Re: CCPcoatings.com] #1747059
02/05/15 03:00 PM
02/05/15 03:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
So what is the maximum recommended temp for break-in on a new set of ceramic coated headers?
Re: Will I Fry My Header Coating? [Re: DaveRS23] #1747060
02/05/15 03:15 PM
02/05/15 03:15 PM
USA
b54406barrel Offline
USA
Saw one being broken in with the hooker ceramic coating. They had put some folded towels on the fenders wells & used a couple of those box fans they got at a goodwill for $10 to aim at the headers. Fired the motor & kicked on the fans. Ran for 20 minutes a 2K. Headers stayed shiny.
Re: Will I Fry My Header Coating? [Re: JohnRR] #1747061
02/05/15 03:21 PM
02/05/15 03:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I don't start an engine for break in unless it has a timing light, vacuum gauge, remote tachometer, and a "real" gauge mounted in the oil sending unit, along with a hand held temp gun, all at the ready installed, along with a large fan, or multiple fans,... to start an engine without any of these things in place is foolish, I want to know at a glance what's going on as the motor is turning 2 grand for the next 15-20 minutes, for the carb(s) settings I usually note the full number of turns for the fuel/air idle screws, and turn them all out 2/3's of their travel (as long as it's not a reverse idle circuit!) for initial start up/break in, and monitor assorted temps of the water, heads, block, intake, exhaust, and vac readings to ensure a happy motor break in period
mike
Re: Will I Fry My Header Coating? [Re: DAYCLONA] #1747062
02/05/15 04:40 PM
02/05/15 04:40 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I fried mine; hookers. Had the timing light ready but the friend I had helping me was too worried about topping off the power steering fluid instead of putting the timing light on it first. It was too late when he noticed that some of the tubes were glowing red. The timing was way retarded at the start. I guess I should have been the one maning the engine compartment while he worked the key and monitored the gauges.
With some of what was mentioned above, I'm sure it might be possible not to fry them though.
Re: Will I Fry My Header Coating? [Re: parksr5] #1747063
02/05/15 05:47 PM
02/05/15 05:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
On my mopars, I use a starter switch attached to my starter relay and start the car under the hood. Or just use a screwdriver on the starter relay. I usually work by myself.
Re: Will I Fry My Header Coating? [Re: Challenger 1] #1747064
02/05/15 06:19 PM
02/05/15 06:19 PM
Spokane Valley, WA
Spokane Valley, WA
Man, this is all super great. I'm about to assemble my exhaust. Is it best to break in the engine with open headers or connected to the muffler system or does it matter?
You guys are awesome!
Lindy
I’m listening.
Re: Will I Fry My Header Coating? [Re: Big Bad Bee] #1747065
02/05/15 08:07 PM
02/05/15 08:07 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Close the exhausts...It's a lot better when you can also hear everything that's happening...
...FAFO...
Re: Will I Fry My Header Coating? [Re: skicker] #1747066
02/05/15 08:21 PM
02/05/15 08:21 PM
USA
USA
100%!
