Re: oil pump for high rpm small block
[Re: Street Monkies]
#1745912
02/03/15 10:57 PM
02/03/15 10:57 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Stock block and 8,000 rpm. I know the melling pump is fine and I've run them. I'd personally would like something better or different Wether it's internal or external. What's good? I've looked at Titan, Petterson, Moroso.
If you find another oil pump for us small block guys let me know too. I also turn my motor 8K rpm and only know about a melling pump for us.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
#1745913
02/03/15 11:05 PM
02/03/15 11:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've done fine with the stock type but HV due to the clearances.. 8000 on each pass.. I do port them a bit and stock spring in it
[Re: RAY1969CARS]
#1745920
02/04/15 01:34 AM
02/04/15 01:34 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would go Peterson R4 single stage wet sump external pump for 740, before I spent a 1000 on that other pump.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1745921
02/04/15 03:17 PM
02/04/15 03:17 PM
Posts: 3,456 Out West
408strokerdart
Out West
ditto!
