oil pump for high rpm small block #1745911
02/03/15 10:36 PM
02/03/15 10:36 PM
In a house near you
Street Monkies Offline OP
In a house near you
Stock block and 8,000 rpm. I know the melling pump is fine and I've run them. I'd personally would like something better or different Wether it's internal or external. What's good? I've looked at Titan, Petterson, Moroso.
Re: oil pump for high rpm small block [Re: Street Monkies] #1745912
02/03/15 10:57 PM
02/03/15 10:57 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
If you find another oil pump for us small block guys let me know too. I also turn my motor 8K rpm and only know about a melling pump for us.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: oil pump for high rpm small block [Re: Street Monkies] #1745913
02/03/15 11:05 PM
02/03/15 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've done fine with the stock type but HV due to
the clearances.. 8000 on each pass.. I do port them
a bit and stock spring in it
Re: oil pump for high rpm small block [Re: MR_P_BODY] #1745914
02/03/15 11:24 PM
02/03/15 11:24 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Same here!!
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: oil pump for high rpm small block [Re: Street Monkies] #1745915
02/03/15 11:35 PM
02/03/15 11:35 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I got this scp (stock car products)pump on mine..9000rpms.works great
Re: oil pump for high rpm small block [Re: slammedR/T] #1745916
02/04/15 12:34 AM
02/04/15 12:34 AM
In a house near you
In a house near you
http://www.titanspeed.com/content/pump/pump_prowet01.html they have pumps but expensive. Also I believe Milodon has one as well. Also nice Plymouth340 I'llll have to check them out.
Re: oil pump for high rpm small block [Re: Street Monkies] #1745917
02/04/15 01:00 AM
02/04/15 01:00 AM
slammedR/T Offline
slammedR/T  Offline
NO WAY!!! will i ever pay $1000 for a wet sump oil pump
racemagnum
Re: oil pump for high rpm small block [Re: slammedR/T] #1745918
02/04/15 01:02 AM
02/04/15 01:02 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Re: oil pump for high rpm small block [Re: RAY1969CARS] #1745919
02/04/15 01:33 AM
02/04/15 01:33 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
This is the pump I have used. They have a standard volume version also. http://stores.precisionoilpumps.com/blueprinted-melling-sb-mopar-high-volume-pump/
Re: oil pump for high rpm small block [Re: RAY1969CARS] #1745920
02/04/15 01:34 AM
02/04/15 01:34 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would go Peterson R4 single stage wet sump external pump for 740, before I spent a 1000 on that other pump.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: oil pump for high rpm small block [Re: 1967dartgt] #1745921
02/04/15 03:17 PM
02/04/15 03:17 PM
Out West
408strokerdart Offline
Out West
ditto!
Re: oil pump for high rpm small block [Re: 408strokerdart] #1745922
02/04/15 03:35 PM
02/04/15 03:35 PM
In a house near you
In a house near you
Yeah for the price that would make the most sense. I did look up SCP pumps and they're $500 for their single stage external wet sump oil pump. Moroso is $690 for their pump. I know there is other manufacturers that have decent pumps. Peterson sounding like the most favorite. But you run into the front drive distributor. What's the story on that? Have to make your own because nothing fits?
