318-390 stroker which head to use #1745413
02/03/15 02:22 AM
02/03/15 02:22 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
built a 318-390 stroker and have a choice of eddy heads 202 160 valves and a set of indy x iron heads 192 162 valves. this is street strip engine.mostly strip thanks Bradley
Re: 318-390 stroker which head to use [Re: roadrunnerreds] #1745414
02/03/15 03:48 AM
02/03/15 03:48 AM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
Check these out: http://immengines.com/indyimmironheads.html
Brian Hafliger
Re: 318-390 stroker which head to use [Re: Brian Hafliger] #1745415
02/03/15 04:14 AM
02/03/15 04:14 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
that's what I was thinking. Have you done a sb stroker 6 pack with these heads ?
Re: 318-390 stroker which head to use [Re: roadrunnerreds] #1745416
02/03/15 12:04 PM
02/03/15 12:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you have these heads now or are you buying.. if
you have them... then the eddy set with 2.02
Re: 318-390 stroker which head to use [Re: roadrunnerreds] #1745417
02/03/15 01:20 PM
02/03/15 01:20 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
i've got a new set of eq bare i'd let u have, pm me if interested,john
Re: 318-390 stroker which head to use [Re: roadrunnerreds] #1745418
02/03/15 06:38 PM
02/03/15 06:38 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I'd go with the Eddy's. The weight savings is a bonus.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 318-390 stroker which head to use [Re: DusterDave] #1745419
02/03/15 10:18 PM
02/03/15 10:18 PM
SoCal
SoCal
What does the weight bonus actually provide??
Brian Hafliger
Re: 318-390 stroker which head to use [Re: Brian Hafliger] #1745420
02/03/15 11:38 PM
02/03/15 11:38 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
It's got something to do with power to weight ratio, and front/rear weight bias. You should already know that.
Re: 318-390 stroker which head to use [Re: DusterDave] #1745421
02/04/15 01:58 AM
02/04/15 01:58 AM
SoCal
SoCal
So 40 extra pounds makes such a huge difference eh? Tell us Duster Dave, how much of a difference? Or should I already know that too??
My duster has always had a cast iron headed small block and yet it leaves hard with better than avg. 60ft.s. 40lbs. off the front end, all things being equal would not equate to very much if anything. But the 20-30 extra HP our Iron heads make over OOTB eddys would definitely amount to a very noticeable difference.
But I'm sure you already knew that!
Gotta love the internet smart a$$e$
Brian Hafliger
Re: 318-390 stroker which head to use [Re: Brian Hafliger] #1745422
02/04/15 02:08 AM
02/04/15 02:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Gotta love self promoters too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 318-390 stroker which head to use [Re: pittsburghracer] #1745423
02/04/15 03:10 AM
02/04/15 03:10 AM
SoCal
SoCal
Your one to talk....
Brian Hafliger
Re: 318-390 stroker which head to use [Re: Brian Hafliger] #1745424
02/04/15 08:40 AM
02/04/15 08:40 AM
Gettysburg Pa
Gettysburg Pa
Thanks for the replies guys. Mr p body i already have both sets of heads. I got the indy heads thinking because the small bore( under 4 inch bore). What is the benefit of the beehive springs?
Re: 318-390 stroker which head to use [Re: roadrunnerreds] #1745425
02/04/15 02:02 PM
02/04/15 02:02 PM
dogdays Offline
dogdays  Offline
If you already have both sets of heads, send the Edelbrocks to Brian (OU812) and have him port them. Best of both worlds. Or the iron heads, which seem to be a favorite of his.
Point is, this guy is a professional who knows his way around a smallblock head.
Beehive springs allow one to use a smaller retainer which takes mass out of the valvetrain, also the shape of the springs makes them less susceptible to harmonic vibration and one can usually use a beehive with a lower seat and/or open load.
Comp Cams really put the idea on the map.
R.
Re: 318-390 stroker which head to use [Re: roadrunnerreds] #1745426
02/04/15 02:11 PM
02/04/15 02:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being you already have the eddie's you would save the
40# on the front and you can also raise the compression
a bit and not fear detonation.. all pluses in my book
Re: 318-390 stroker which head to use [Re: MR_P_BODY] #1745427
02/04/15 02:22 PM
02/04/15 02:22 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Careful, Mr. P. Your comments might anger ou812! He's trying to make a sale here!
Re: 318-390 stroker which head to use [Re: DusterDave] #1745428
02/04/15 03:04 PM
02/04/15 03:04 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Let's explore this, based on a comment from above...
A given motor has 9.5:1 with iron heads and we add aluminum heads and get to 10.5:1. Are there REALLY any gains from the CR increase, being that aluminum dissipates heat so fast??
Re: 318-390 stroker which head to use [Re: cudadoug] #1745429
02/04/15 03:08 PM
02/04/15 03:08 PM
Renton Washington
Triple Threat Offline
Renton Washington
I went 10.75@123 with IMM (Brian) ported eddies on my pump gas 390" engine with a solid cam. 3450#
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 318-390 stroker which head to use [Re: cudadoug] #1745430
02/04/15 03:14 PM
02/04/15 03:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In reality they pretty much became equal on the compression
aspect but the alum head is better on the detonation
and you still have the weight savings
Re: 318-390 stroker which head to use [Re: MR_P_BODY] #1745431
02/04/15 07:17 PM
02/04/15 07:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Iron VS aluminum is no significant power difference if both heads are the same otherwise. Aluminum ALLOWS more compression it does not NEED more compression. That myth has been disproved many times.
Unless traction is a big problem for you then I would sell the eddys and use the money to have Brian port the iron heads and still have money in my pocket.
I am building a motor for my own Dakota R/T with iron heads and will just do everything I can to make it hook, if I have to down the road I will step up to aluminum but only after I exhaust all other reaonable posibilities, then it will probably be in the form of a new style hemi and selling my current 392 stroker. I have 10.2 compression, tight quench, magnum heads and a small cam (stock 5.9) and no detonation.
Re: 318-390 stroker which head to use [Re: HotRodDave] #1745432
02/06/15 09:46 PM
02/06/15 09:46 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Its interesting you say that HRD - in our climate we'd go with the alloy head every time....less risk of detonation at 10:1 static with a mild cam....and less cooling issues - but our gas is also pretty cr@p so the heat dissipation of alloy helps there as well.
My point is only this - we should never underplay the effects of thermal dynamics when choosing performance parts....
