2004 Ram 1500 Stalling/Trans Issues #1744764
02/02/15 02:46 AM
02/02/15 02:46 AM
Hawaii
Dodgeballs Offline OP
Hawaii
So when the truck is cold, sometimes the motor will stumble and/or stall. It seems to be idling fine and has lots of power. I think it may be related to the trans as it takes a few seconds after being in neutral for the trans to move the truck. It used to be worse. I would get a shudder and take a long time to get into gear before. I changed the fluid/filter and it seemed to get better - but the old fluid and filter were clean. The it was good for a while, but started slipping again. This time the fluid was low. Like 3 quarts. The truck only has 80,000 miles on it, and I see no leaks and notice no smoke as if it was getting sucked into the motor or something weird.
I added fluid and it got better, but still is slow to get into gear and stalls. But is still better than when the problem first appeared. I am scratching my head on this.
I forgot to add - the stalling is when I come to a stop. Not when I start the car or when it's idling or driving.
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: Dodgeballs] #1744765
02/03/15 02:44 AM
02/03/15 02:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is it a 5.7 Hemi with a 45RFE trans ? Ron
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: Dodgeballs] #1744766
02/03/15 06:06 PM
02/03/15 06:06 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
that trans is known for cracks in the trans filter that make it loose pressure thus causing slow performance and stalling.
Aftermarket filters are even worse.
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: joewhite440] #1744767
02/03/15 11:39 PM
02/03/15 11:39 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Not so much cracking, although that has happened, the backpressure has been shown to actually split the main filter, (there are 2 in the pan),the filters tend to come loose where they are pushed up into the pump. A 125 filter seal will help hold the filter much better than a stock OE seal.
If the filter is sucking air, it cannot push the converter clutch off the lid and will drag/stall the engine.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: zzyzxpat] #1744768
02/04/15 03:12 AM
02/04/15 03:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Same if its low on fluid as I saw that happen a few times where it stalls the eng since it can keep the clutch converter clutch from applying some on the 45 and 545RFE's. Ron
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: 383man] #1744769
02/04/15 05:41 PM
02/04/15 05:41 PM
Hawaii
Hawaii
So sorry for getting back to you guys late,
I got slammed with work and family being sick.
It is a 5.7 Hemi and, I think, a 45RFE (It's been a while since I changed the fluid and I remember being unsure of which trans it was until I pulled the pan). I can't believe I didn't put that in the post!
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: zzyzxpat] #1744770
02/04/15 05:44 PM
02/04/15 05:44 PM
Hawaii
Hawaii
What is a 125 filter seal? Is this a GM seal? I read in another thread about some GM filter or seal or something like that, but I can't find the thread.
Is this the seal?:
http://www.makcotransmissionparts.com/64379.html
What filters/seal do you guys recommend?
Again, thanks for the answers and sorry for the late reply.
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: Dodgeballs] #1744771
02/04/15 06:04 PM
02/04/15 06:04 PM
Hawaii
Hawaii
OK.
I found the post buried many pages down.
https://board.moparts.org/ubbthreads/show...e=6#Post8401558
I will try the 125 filter seal and see if that helps.
Thank you guys!
Re: 2004 Ram 1500 Stalling/Trans Issues [Re: Dodgeballs] #1744772
02/04/15 07:09 PM
02/04/15 07:09 PM
Hawaii
Hawaii
For anyone else out there having issues, I found this youtube video talking about the filter. A commenter also brings up the 125 seal.
https://www.youtube.com/watch?v=lyD0LKVs8MA
