Clutch safety switch repair #1743495
01/31/15 09:47 PM
01/31/15 09:47 PM
RI
cudascooter Offline OP
RI
Hi, Does anyone know the best way to repair the clutch switch wire for my 70 Cuda? I have attached a pic. Thanks
Re: Clutch safety switch repair [Re: cudascooter] #1743496
01/31/15 10:40 PM
01/31/15 10:40 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
I restore these 2947858 clutch switches by making the tubular copper rivets to re-attach the ground panel and eyelet. On this JSR thread, if you scroll down to the June 19, 2013 post, shows one going through a restoration.
https://board.moparts.org/ubbthreads/show...e=0&fpart=2
Re: Clutch safety switch repair [Re: cudascooter] #1743497
01/31/15 10:41 PM
01/31/15 10:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
take it apart , drill out the crimped rivet , new connector on the wire and either a new rivet or a small screw and locknut ??
Re: Clutch safety switch repair [Re: Slotts] #1743498
01/31/15 10:54 PM
01/31/15 10:54 PM
RI
RI
Thanks Jim!!
