Re: Anyone used Lokar Kickdown and throttle Cables?
[Re: Adam71Charger]
#1742458
02/01/15 10:21 PM
02/01/15 10:21 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"So what Im hearing is the throttle cable has worked fine for most, but only a few have had success with the kickdown cable/brackets." I have run the Lokar throttle cable on my race car for the past 10 years or so without any problems but when I was redoing my 68 Charger last year I went with the Bouchillon throttle/kickdown kit as it was supposed to be the easiest to install. I changed from a 383 to a 440 and the stock stuff would not work(too short). http://www.bpeusa.com/BPEaccBracket.asp Pretty expensive but great quality easy to install and kick down works great! It utilizes stock throttle cable and the kick down is adjustable so you can dial in your kick down. Mike ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Adam71Charger]
#1742459
02/02/15 12:00 PM
02/02/15 12:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
You need to ask yourself WHY? Why do I need an aftermarket set-up. I have modified factory pieces to suit my needs. The throttle cable takes like 10 minutes. I managed to use the stock throttle cable (off a b-body big block) for my 440-6 stage VI headed w/ 1/2" spacers engine. Al It requires is adding some lenght to it.
