Re: Oil pump pick up to pan rail distance
[Re: UCUDANT]
#1741555
01/29/15 11:09 PM
01/29/15 11:09 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Which type and size motor block are you looking for this informatiom from?
[Re: Cab_Burge]
#1741557
01/29/15 11:43 PM
01/29/15 11:43 PM
Posts: 8,144 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Ohh dang. Sorry, it's a 340
[Re: UCUDANT]
#1741559
01/31/15 04:24 PM
01/31/15 04:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your using the factory round pick up with a 3/4 bottom to it put the bottom at a 1/4" up off the bottom
[Re: UCUDANT]
#1741562
02/01/15 03:23 AM
02/01/15 03:23 AM
MR_P_BODY
What I need is the distance from the pan rail to the center of the oil pumps threaded hole
Sorry... your on your own there.. I'm not at home to measure a block
