Oil pump pick up to pan rail distance #1741552
01/29/15 08:21 AM
01/29/15 08:21 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I scored a used deep sump oil pan, and also have a milidon pick up laying around. I can mock it up later but can anyone provide the distance from the blocks pan rail (gasket surface) to the center of the oil pump pick up tube threaded hole?
Re: Oil pump pick up to pan rail distance [Re: UCUDANT] #1741553
01/29/15 10:21 PM
01/29/15 10:21 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: Oil pump pick up to pan rail distance [Re: UCUDANT] #1741554
01/29/15 11:05 PM
01/29/15 11:05 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
I'll try to answer this . First take your swinging pick find the true center of the pickup holes,scrib a line or sharpie a line left to right from hole to hole. Measure center to center of the holes and write that distance down. On a flat surface place the pickup end on a piece of 1/4 inch flat stock,measure to the flat surface. That is the distance from the bottom of pan to your pickup holes. Mark that line on your pan,mark the center to center measurement you wrote down.center punch and drill some holes. Hope this helps.
Re: Oil pump pick up to pan rail distance [Re: UCUDANT] #1741555
01/29/15 11:09 PM
01/29/15 11:09 PM
Which type and size motor block are you looking for this informatiom from?
Re: Oil pump pick up to pan rail distance [Re: Cab_Burge] #1741556
01/29/15 11:26 PM
01/29/15 11:26 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
Guess I answered a question that was not really ask,my mistake.
Re: Oil pump pick up to pan rail distance [Re: Cab_Burge] #1741557
01/29/15 11:43 PM
01/29/15 11:43 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Ohh dang. Sorry, it's a 340
Re: Oil pump pick up to pan rail distance [Re: UCUDANT] #1741558
01/31/15 04:16 PM
01/31/15 04:16 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: Oil pump pick up to pan rail distance [Re: UCUDANT] #1741559
01/31/15 04:24 PM
01/31/15 04:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your using the factory round pick up with a 3/4
bottom to it put the bottom at a 1/4" up off the bottom
Re: Oil pump pick up to pan rail distance [Re: MR_P_BODY] #1741560
01/31/15 05:19 PM
01/31/15 05:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I like .250 to .375. Depending on pan and baffling
Re: Oil pump pick up to pan rail distance [Re: FastmOp] #1741561
02/01/15 03:20 AM
02/01/15 03:20 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
What I need is the distance from the pan rail to the center of the oil pumps threaded hole
Re: Oil pump pick up to pan rail distance [Re: UCUDANT] #1741562
02/01/15 03:23 AM
02/01/15 03:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry... your on your own there.. I'm not at home
to measure a block
Re: Oil pump pick up to pan rail distance [Re: MR_P_BODY] #1741563
02/02/15 04:03 PM
02/02/15 04:03 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
