Oliver I-beams or Manley Pro I-beams? #1741332
01/28/15 11:00 PM
01/28/15 11:00 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'm building a 572 B1 motor for a buddy. Callies 4.5" crank, World aluminum block, B1s fully ported.
It will be a pump gas motor and then spay it 350-500, Drag Week car
Trying to decide between the Manley Pro I-beams and the Oliver I-beams. Both with ARP625 bolts.
7.100 2.200 and Chrysler width
Both are rated for over 1,000 HP.
Hoping to make 900-950 on the motor and then spray it to 1,300hp
Does anyone have any experience with those and have any opinions on either one?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741333
01/28/15 11:25 PM
01/28/15 11:25 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
Olivers all the way.
Re: Oliver I-beams or Manley Pro I-beams? [Re: jkwedge540] #1741334
01/29/15 12:21 AM
01/29/15 12:21 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Olivers
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741335
01/29/15 12:47 AM
01/29/15 12:47 AM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
Olivers in my 605 plus fogger and plate kit no complaints here
8.40 @165
Re: Oliver I-beams or Manley Pro I-beams? [Re: avenger572] #1741336
01/29/15 12:54 AM
01/29/15 12:54 AM
Dyno1 Offline
Dyno1  Offline
I like the Manley rods.
Re: Oliver I-beams or Manley Pro I-beams? [Re: avenger572] #1741337
01/29/15 01:07 AM
01/29/15 01:07 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
8.40 @165
I bought Olivers because the Crowers were a little heavier, but they are both good rods.
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741338
01/29/15 01:07 AM
01/29/15 01:07 AM
AndyF Offline
AndyF  Offline
I upgraded to 7.100 Oliver rods last time I freshened up my dyno mule.
Re: Oliver I-beams or Manley Pro I-beams? [Re: AndyF] #1741339
01/29/15 01:39 AM
01/29/15 01:39 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
How do Carrillo's stack up against Oliver/Manleys?
Re: Oliver I-beams or Manley Pro I-beams? [Re: ScottSmith_Harms] #1741340
01/29/15 01:46 AM
01/29/15 01:46 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Not in same ball park.
If not a carrillo I would recommend callies ultra rods with good bolts (arp new age 625)
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741341
01/29/15 01:51 AM
01/29/15 01:51 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
You can't go wrong with ether one both are made in the USA .oliver is a bit better I think I have ran both .nice stuff ether way.....
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Oliver I-beams or Manley Pro I-beams? [Re: WHITEDART] #1741342
01/29/15 02:12 AM
01/29/15 02:12 AM
Washington
madscientist Offline
Washington
I wouldn't say for sure the Manleys are made in the USA. In fact, very few rods are made here. If you are not going to pay for the Olivers, dig around and find a much cheaper chinese knock off that's not in a name brand box. Check and fit both ends and go.
I'm tired of companies claiming their junk is made here, when it's only boxed here, or at most, finished machined here.
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741343
01/29/15 11:07 AM
01/29/15 11:07 AM
an8sec70cuda Offline
Oliver. I have their billet steel rods in my 572" hemi. Over 800 hp on motor plus 250 hp NOS.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Oliver I-beams or Manley Pro I-beams? [Re: madscientist] #1741344
01/29/15 11:16 AM
01/29/15 11:16 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
The Callies Ultra series rods are manufactured 100% in there Fostoria Ohio facility.
Re: Oliver I-beams or Manley Pro I-beams? [Re: WHITEDART] #1741345
01/29/15 11:45 AM
01/29/15 11:45 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
So you are saying Carrillos are better than Olivers or Manleys?
Re: Oliver I-beams or Manley Pro I-beams? [Re: ScottSmith_Harms] #1741346
01/29/15 12:03 PM
01/29/15 12:03 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
The problems Ron had with with Oliver rods on the 501" small block build would scare me a little.
68 Barracuda Formula S 340
Re: Oliver I-beams or Manley Pro I-beams? [Re: Bad340fish] #1741347
01/29/15 01:03 PM
01/29/15 01:03 PM
Tulsa, Ok
Tulsa, Ok
I would go with Callies Ultra rods with 625 bolts but they don't make a 7.100 2.200 journal with mopar width.
My options are :
- Custom R&R rods (ARP2000) for $1,800 or $2,250 with APR625s
- Manley Pro I-beam (ARP2000) $1,425 or $1874 with ARP625s
- Oliver billet I-Beams (L19 bolts) $1,380 or $1,830 with ARP625s
So I think the Olivers have better rod bolts for a little bit less.
I think any will do the job just fine.
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741348
01/29/15 01:08 PM
01/29/15 01:08 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Is the Callies L-19 bolt any count? I am disappointed they didn't use ARP 2000 on those $1200 rods.
Re: Oliver I-beams or Manley Pro I-beams? [Re: WadeMetzinger] #1741349
01/29/15 01:10 PM
01/29/15 01:10 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Why not a aluminum rod? Help with the shock load of the nitrous not transferring to the crank or mains.
Carrillo are a lot better then these choices.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Oliver I-beams or Manley Pro I-beams? [Re: Airwoofer] #1741350
01/29/15 01:10 PM
01/29/15 01:10 PM
Tulsa, Ok
Tulsa, Ok
Callies isn't an option, they don't make a 7.100 2.200 mopar width rod, I've asked.
Re: Oliver I-beams or Manley Pro I-beams? [Re: 1967dartgt] #1741351
01/29/15 01:12 PM
01/29/15 01:12 PM
Tulsa, Ok
Tulsa, Ok
Aluminum rods on street motor is not a good idea, I've spoken to most of the aluminum rod manufactures and they don't recommend and tell me to go steel.
