Oliver I-beams or Manley Pro I-beams?
#1741332
01/28/15 11:00 PM
01/28/15 11:00 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'm building a 572 B1 motor for a buddy. Callies 4.5" crank, World aluminum block, B1s fully ported.
It will be a pump gas motor and then spay it 350-500, Drag Week car
Trying to decide between the Manley Pro I-beams and the Oliver I-beams. Both with ARP625 bolts.
7.100 2.200 and Chrysler width
Both are rated for over 1,000 HP.
Hoping to make 900-950 on the motor and then spray it to 1,300hp
Does anyone have any experience with those and have any opinions on either one?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Oliver I-beams or Manley Pro I-beams?
[Re: avenger572]
#1741336
01/29/15 12:54 AM
01/29/15 12:54 AM
Dyno1
[Re: avenger572]
#1741337
01/29/15 01:07 AM
01/29/15 01:07 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Olivers in my 605 plus fogger and plate kit no complaints here 8.40 @165
I bought Olivers because the Crowers were a little heavier, but they are both good rods.
[Re: ScottSmith_Harms]
#1741340
01/29/15 01:46 AM
01/29/15 01:46 AM
Posts: 1,784 PA
W5DART66
PA
How do Carrillo's stack up against Oliver/Manleys?
Not in same ball park.
If not a carrillo I would recommend callies ultra rods with good bolts (arp new age 625)
[Re: WadeMetzinger]
#1741341
01/29/15 01:51 AM
01/29/15 01:51 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
You can't go wrong with ether one both are made in the USA .oliver is a bit better I think I have ran both .nice stuff ether way.....
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1741342
01/29/15 02:12 AM
01/29/15 02:12 AM
Posts: 4,457 Washington
madscientist
Washington
I wouldn't say for sure the Manleys are made in the USA. In fact, very few rods are made here. If you are not going to pay for the Olivers, dig around and find a much cheaper chinese knock off that's not in a name brand box. Check and fit both ends and go.
I'm tired of companies claiming their junk is made here, when it's only boxed here, or at most, finished machined here.
[Re: WadeMetzinger]
#1741343
01/29/15 11:07 AM
01/29/15 11:07 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Oliver. I have their billet steel rods in my 572" hemi. Over 800 hp on motor plus 250 hp NOS.
[Re: WHITEDART]
#1741345
01/29/15 11:45 AM
01/29/15 11:45 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
So you are saying Carrillos are better than Olivers or Manleys?
#1741346
01/29/15 12:03 PM
01/29/15 12:03 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The problems Ron had with with Oliver rods on the 501" small block build would scare me a little.
68 Barracuda Formula S 340
[Re: WadeMetzinger]
#1741349
01/29/15 01:10 PM
01/29/15 01:10 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Why not a aluminum rod? Help with the shock load of the nitrous not transferring to the crank or mains.
Carrillo are a lot better then these choices.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Airwoofer]
#1741350
01/29/15 01:10 PM
01/29/15 01:10 PM
WadeMetzinger
Tulsa, Ok
Is the Callies L-19 bolt any count? I am disappointed they didn't use ARP 2000 on those $1200 rods.
Callies isn't an option, they don't make a 7.100 2.200 mopar width rod, I've asked.
[Re: 1967dartgt]
#1741351
01/29/15 01:12 PM
01/29/15 01:12 PM
WadeMetzinger
Tulsa, Ok
Aluminum rods on street motor is not a good idea, I've spoken to most of the aluminum rod manufactures and they don't recommend and tell me to go steel.
