Re: Demon trunk lock - Please help
[Re: FJR doc]
#1741085
01/28/15 03:29 PM
01/28/15 03:29 PM
Posts: 304 Export, PA
jayyohe
Export, PA
Take out the back seat and crawl into the trunk. You can then use a regular screwdriver to turn the latch from inside. I wonder if the metal tab that runs from the lock tumbler to the latch broke.
No can do. I have a welded in rear firewall that has fresh carpeting glued to it. Thanks for the suggestion though.
[Re: TJP]
#1741086
01/28/15 03:32 PM
01/28/15 03:32 PM
jayyohe
Export, PA
go through the back seat to the trunk. Remove the clip holding the lock cylinder and remove the lock (someone outside to catch the lock would be helpful). once the lock is removed use a flashlight and a long skinny screwdriver to un lacth the mechanism.
And FYI they normally use a different key for the trunk lock
Thanks. My car has 2 keys. One that starts the car and the other one that opens the doors and trunk. I can't crawl through because I have a welded in rear firewall for racing. And I just had new sound deadener and carpeting glued to it.
[Re: jayyohe]
#1741087
01/28/15 03:36 PM
01/28/15 03:36 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
Your either going to have to drill a hole through the rear firewall large enough to pass a long tool through or drill/punch out the trunk lock.
Why welded in?
[Re: nomore65BelvJim]
#1741089
01/28/15 03:47 PM
01/28/15 03:47 PM
jayyohe
Export, PA
Why welded in?
I have a metal rear firewall that was tack welded in at my request. It's needed for racing when battery is mounted in the trunk.
[Re: demon440]
#1741093
01/29/15 04:10 AM
01/29/15 04:10 AM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
Houdini Lock Lubricant We inherited a truck that wasn't drove in a few years All door/ tailgate lock would not operate went by the lock smith shop to inquire about cost to repair he shot the locks with this lubricant all locks started working I was very surprised because i was ready to remove the locks for him to clean/ repair.. http://store.mylockstore.net/catalog/product/417a69d8993f47a5a9d4632bf7a2700a
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: draginmopars]
#1741094
01/29/15 05:53 AM
01/29/15 05:53 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Use a small drill bit and drill out the pins of the lock. Then use a screwdriver to open the lock.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
