Demon trunk lock - Please help #1741081
01/28/15 03:21 PM
01/28/15 03:21 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
So I go down to the garage this weekend hoping to open the trunk to add some staybil to my fuel cell and remove my battery from the trunk to put it on a trickle charger and my key will not open the trunk lock. I tried pushing down on the deck lid while turning the key and pulling up on the deck lid while turning the key. I wiggled the key back and forth, up and down and all that jazz and it still won't open. I only have this one key for the door locks and trunk lock and it honestly is worn so thin that I am not surprised that it isn't working properly.
Any suggestions on how to get my trunk open so I can replace the lock cylinder? I'm considering calling AAA to see if they can pop it open but afraid of what they might do to my freshly painted car.
Thanks everyone,
Jay
jayyohe@yahoo.com Export, PA 1971 Dodge Demon - 440/4-Speed
Re: Demon trunk lock - Please help [Re: jayyohe] #1741082
01/28/15 03:28 PM
01/28/15 03:28 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Take out the back seat and crawl into the trunk. You can then use a regular screwdriver to turn the latch from inside. I wonder if the metal tab that runs from the lock tumbler to the latch broke.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Demon trunk lock - Please help [Re: jayyohe] #1741083
01/28/15 03:28 PM
01/28/15 03:28 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Re: Demon trunk lock - Please help [Re: jayyohe] #1741084
01/28/15 03:29 PM
01/28/15 03:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
go through the back seat to the trunk. Remove the clip holding the lock cylinder and remove the lock (someone outside to catch the lock would be helpful). once the lock is removed use a flashlight and a long skinny screwdriver to un lacth the mechanism.
And FYI they normally use a different key for the trunk lock
Re: Demon trunk lock - Please help [Re: FJR doc] #1741085
01/28/15 03:29 PM
01/28/15 03:29 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
No can do. I have a welded in rear firewall that has fresh carpeting glued to it. Thanks for the suggestion though.
Re: Demon trunk lock - Please help [Re: TJP] #1741086
01/28/15 03:32 PM
01/28/15 03:32 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
Thanks. My car has 2 keys. One that starts the car and the other one that opens the doors and trunk. I can't crawl through because I have a welded in rear firewall for racing. And I just had new sound deadener and carpeting glued to it.
Re: Demon trunk lock - Please help [Re: jayyohe] #1741087
01/28/15 03:36 PM
01/28/15 03:36 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Your either going to have to drill a hole through the rear firewall large enough to pass a long tool through or drill/punch out the trunk lock.
Why welded in?
Re: Demon trunk lock - Please help [Re: Fat_Mike] #1741088
01/28/15 03:45 PM
01/28/15 03:45 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
https://board.moparts.org/ubbthreads/show...rue#Post8177481
Thanks...good info but not what I was hoping to do. My luck I will screw up the paint around the lock when drilling it out.
Re: Demon trunk lock - Please help [Re: nomore65BelvJim] #1741089
01/28/15 03:47 PM
01/28/15 03:47 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
Why welded in?
I have a metal rear firewall that was tack welded in at my request. It's needed for racing when battery is mounted in the trunk.
Re: Demon trunk lock - Please help [Re: jayyohe] #1741090
01/28/15 04:13 PM
01/28/15 04:13 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
OK, go down to your local hardware store and buy some dry lock lubricant. It's only a couple bucks, and worth a shot. I've used it on a couple outdoor locks with success. http://www.homedepot.com/p/The-Hillman-Group-3-g-Powdered-Graphite-Lubricant-703185/100137063
Re: Demon trunk lock - Please help [Re: Fat_Mike] #1741091
01/28/15 05:20 PM
01/28/15 05:20 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Seven sixteenths or Half inch drill bit and drill out the lock from the outside. then when the lock assembly has hole through it take a screw driver and trip the latch. requires new key assembly.
Re: Demon trunk lock - Please help [Re: MoparforLife] #1741092
01/29/15 02:38 AM
01/29/15 02:38 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
go get a new key made.
or maybe one of us other Demon owners has a
spare key that is the same.
Re: Demon trunk lock - Please help [Re: demon440] #1741093
01/29/15 04:10 AM
01/29/15 04:10 AM
smyrna,tn
draginmopars Offline
smyrna,tn
Houdini Lock Lubricant
We inherited a truck that wasn't drove in a few years
All door/ tailgate lock would not operate
went by the lock smith shop to inquire about cost to repair
he shot the locks with this lubricant
all locks started working
I was very surprised
because i was ready to remove the locks for him to clean/ repair..
http://store.mylockstore.net/catalog/product/417a69d8993f47a5a9d4632bf7a2700a
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Demon trunk lock - Please help [Re: draginmopars] #1741094
01/29/15 05:53 AM
01/29/15 05:53 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Use a small drill bit and drill out the pins of the lock. Then use a screwdriver to open the lock.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Demon trunk lock - Please help [Re: GTSDart340] #1741095
01/29/15 10:28 AM
01/29/15 10:28 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
The trouble opening your trunk will depend on what is wrong. If the trouble is the key/tumbler assembly , drilling it will get it open . if the lever connecting the key assembly to the trunk latch is broken or not connected, drilling the tumblers ain't going to help. But of course , it's your best bet right now. However the first thing I would do is get a new key made and see what happens then .
Re: Demon trunk lock - Please help [Re: mopar_man] #1741096
01/29/15 12:27 PM
01/29/15 12:27 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
Thanks for all the great suggestions. I'm going to try squirting some fine graphite lubricant in it (I have some from lubing up my kids derby car)and if that don't work I'm going get a new key made. Then I'll try the other things you guys mentioned. Last thing to try would be drilling it out. Hope I don't have to go that route.
I'll update this thread following each step I take.
Thanks again folks.
Re: Demon trunk lock - Please help [Re: jayyohe] #1741097
01/29/15 01:01 PM
01/29/15 01:01 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
Just spoke to a local locksmith and they told me to bring the key to them and they will try duplicate the codes and get me an original style key. 15$ Fingers crossed XXXXXXX
Re: Demon trunk lock - Please help [Re: jayyohe] #1741098
01/29/15 01:26 PM
01/29/15 01:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If the key thing doesn't work I might suggest a dremel tool vs the drilling.
It will be a slower process but more controllable with less chance of damaging the paint or tail panel
Re: Demon trunk lock - Please help [Re: jayyohe] #1741099
01/29/15 01:27 PM
01/29/15 01:27 PM
Vesper,Wisconsin U.S.A
DusterJeff Offline
DusterJeff  Offline
Did you try squirting some WD-40 in the lock and gently wiggling it with the key afterward??????
Do Something..Lead..Follow..or get the {Beep} out of the way..
Re: Demon trunk lock - Please help [Re: jayyohe] #1741100
01/29/15 04:32 PM
01/29/15 04:32 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The key should open the door and be used in the ignition, that would be a Pentastar style key. The key that opens the trunk is a round style key. Did you ever use the key that doesn't work in the lock before?
JB Rhinehart, Realist
A-Body's RULE!
