727 race rebuild question #1740522
01/27/15 06:59 PM
01/27/15 06:59 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
I will be rebuilding my 727 in the near future. It's stock from 1979 and needs attention. I have a manual (forward pattern) valve body. I'm not going trans brake so what parts should I use for the rebuild? It's going behind a 650 hp small block.
Re: 727 race rebuild question [Re: 79410aspenrt] #1740523
01/27/15 07:02 PM
01/27/15 07:02 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
In our Hemi Nostalgia SS we just go to NAPA, get a rebuild kit and use it. Torqueflites are good stuff, you'll be fine.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: 727 race rebuild question [Re: Steve1118] #1740524
01/27/15 09:49 PM
01/27/15 09:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If your VB does not have the LBA then I highly recommend getting a billet front drum.
Other than that, not much else special is needed.
Call John at CRT. He will get you hooked up right.
Re: 727 race rebuild question [Re: 79410aspenrt] #1740525
01/27/15 10:18 PM
01/27/15 10:18 PM
South Carolina
carhunter Offline
carhunter  Offline
South Carolina
I just rebuilt mine last summer I have a billet drum, red racing clutches and ultimate sprag.I have about 750hp.My old trans just had a rebuild kit and shift kit didn't hold up to big hp.
Re: 727 race rebuild question [Re: carhunter] #1740526
01/27/15 10:49 PM
01/27/15 10:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Add Kolene steels with the Alto red clutches.
Check the splines of the low gear set, if they are cracking you will want a steel splined low gear set
Re: 727 race rebuild question [Re: 451Mopar] #1740527
01/28/15 12:14 AM
01/28/15 12:14 AM
Saskatchewan (SK)
Saskatchewan (SK)
I will be spraying a 150 shot of NOS. does this change the parts that are needed?
Re: 727 race rebuild question [Re: 79410aspenrt] #1740528
01/28/15 12:34 AM
01/28/15 12:34 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
smooth clutches in the rear clutch, linned or waffled clutches in the front clucth(direct) if no LBA valve body then get a billet front(direct) drum. If LBA valve body then a 47RE or BB 727 front drum will work, bolt-in rear sprag,wide cast kickdown band red lined, carbon low reverse band, billet rear servo, BB 727 planets will work. teflon seal ring kit, rear vent with catch can. Also the 727 handbook would be a good idea, it will explain some of the tricks like how to modify the front servo and getting a ported stator support shaft for better feed to the front clutch.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 727 race rebuild question [Re: WILD BILL] #1740529
01/28/15 03:31 PM
01/28/15 03:31 PM
Az
Crizila Offline
Crizila  Offline
Az
That's what I did with my stock 79 727. It's been a while, but the kit he put together for me ( for a 10 second car) included a steel front drum, bolt in sprag, stouter band link, low drag seals. I already had a LBA valve body. Been trouble free for a long time now. Forgot, added an additional clutch disc for 3rd gear - involved a skinnier snap ring - think the kit had several in it to choose from.
Fastest 300
Re: 727 race rebuild question [Re: 79410aspenrt] #1740530
01/28/15 04:20 PM
01/28/15 04:20 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The 727s are tough and a 150 shot will be no problem, though it would be best to use it in 2nd or 3rd to begin with. Then after you get used to the way it feels...go for it all the way through....YeeHaw!!!!!!!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 727 race rebuild question [Re: Polarapete] #1740531
01/28/15 04:34 PM
01/28/15 04:34 PM
Up a holler, down a crick
booger Offline
booger  Offline
FWIW, since LBA valve bodies have been mentioned, I thought I'd mention that there's ancillary work to do in order to get that to work if yo have a reverse shifting pattern VB. I'd say exactly what it is, but don't have the sheet that came with mine with me. IIRC there's a couple of holes to drill somewhere.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: 727 race rebuild question [Re: booger] #1740532
01/28/15 06:31 PM
01/28/15 06:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the forward pattern VB was built from a kit (TF-3, Manual Pack) it is already LBA.
Re: 727 race rebuild question [Re: John_Kunkel] #1740533
01/28/15 06:44 PM
01/28/15 06:44 PM
booger Offline
booger  Offline
Thanks I clarified my post. This is the link to the instructions I mentioned if anyone cares. I had it in my head that it was just a matter of changing the valve body to get the LBA to work. http://www.coanracing.com/PDFS/InstallInstructions/COA-42011.pdf
