727 bb or sb easiest way to tell difference #1739671
01/26/15 10:52 PM
01/26/15 10:52 PM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
I guess I am looking for difference between top two bolt holes. The one I have measures 7 5/16.
Re: 727 bb or sb easiest way to tell difference [Re: Cuda367] #1739672
01/26/15 11:05 PM
01/26/15 11:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Looks like C-C on top holes for BB is 6.42. SB is 7.76.
Re: 727 bb or sb easiest way to tell difference [Re: Cuda367] #1739673
01/26/15 11:07 PM
01/26/15 11:07 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Re: 727 bb or sb easiest way to tell difference [Re: 451Cuda] #1739674
01/27/15 12:28 AM
01/27/15 12:28 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The SB 727 has a smaller dust shield because of the two large bolt holes at 7 and 5 o'clock for the support struts to the block. Easy enough. No reason to measure anything, though the 727 was made for the AMC V-8, too and I really don't care about those
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 727 bb or sb easiest way to tell difference [Re: Polarapete] #1739675
01/27/15 12:39 AM
01/27/15 12:39 AM
moparx Offline
moparx  Offline
you don't have to measure any thing if you just look at the starter nose placement. the smallblock nose is at approximately 4:30, while the big block placement is at 3:00. easy peasy.
Re: 727 bb or sb easiest way to tell difference [Re: moparx] #1739676
01/27/15 01:05 AM
01/27/15 01:05 AM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
Thank guys! saved me a lot of lifting and at 68 that is important!!!!
Re: 727 bb or sb easiest way to tell difference [Re: Cuda367] #1739677
01/27/15 04:41 PM
01/27/15 04:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Easiest way to tell is to look at the bottom four bolts on the bellhousing face, BB has four equal sized bolt holes while the SB has two small and two large.
Re: 727 bb or sb easiest way to tell difference [Re: Polarapete] #1739678
01/30/15 01:17 AM
01/30/15 01:17 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Yes 727 was made for the AMC crowd , however the starter was on the chevy side .
Re: 727 bb or sb easiest way to tell difference [Re: mopar_man] #1739679
01/31/15 02:18 PM
01/31/15 02:18 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lol I.H.C had a 727 also!
