Weight distribution hitches for 28' race trailer. #1736851
01/23/15 01:49 PM
01/23/15 01:49 PM
Richmond, Tx. (Houston)
GTSDave Offline OP
GTSDave  Offline OP
Looks like we will be running several races out of state with the closest one over 1k away.
Last year on the way back from St. Louis we had a stretch that was very windy and caused a good bit of sway in my truck/trailer combo. Also, when another vehicle would pass me in all that wind, it wanted to pull me over to their lane. I am thinking I needed to either change my tire setup, and or add a weight distribution hitch. After a little web surfing it seems there are lots of different brands, with options I don't know I need.
What type of weight distribution hitches should I be looking at for my 28' bumper pull trailer?
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Weight distribution hitches for 28' race trailer. [Re: GTSDave] #1736852
01/23/15 01:58 PM
01/23/15 01:58 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I used this one on my camper and it works well. Just make sure it is set up properly or it won`t work like it is intended. http://www.etrailer.com/Weight-Distribution/Reese/RP66074.html BTW, what do you mean when you say bumper pull. I hope you have a trailer hitch installed.
Re: Weight distribution hitches for 28' race trailer. [Re: mopars4ever] #1736853
01/23/15 02:05 PM
01/23/15 02:05 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Super nice one, have towed a trailer with that set up and it was so much better then my weight distribution hitch with no sway control.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Weight distribution hitches for 28' race trailer. [Re: mopars4ever] #1736854
01/23/15 02:07 PM
01/23/15 02:07 PM
Az
Crizila Offline
Crizila  Offline
Az
and make sure you have a minimum of 10% of the GTW at the point of trailer to tow vehicle connection.
Fastest 300
Re: Weight distribution hitches for 28' race trailer. [Re: Crizila] #1736855
01/23/15 02:38 PM
01/23/15 02:38 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Where is the car positioned when you are loaded?
All the way to the front, or all the way to the back?
Mo' Farts
Moderated by "tbagger".
Re: Weight distribution hitches for 28' race trailer. [Re: Grizzly] #1736856
01/23/15 02:57 PM
01/23/15 02:57 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
You might consider a trailer tongue weight scale to make sure my trailer is properly balanced. Got mine from e.trailer also. Was surprised that I had too much tongue weight. Should only be 10-15% of trailer weight.
Re: Weight distribution hitches for 28' race trailer. [Re: Dart Racer] #1736857
01/23/15 04:30 PM
01/23/15 04:30 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Once you tow with a dually, you will find it hard to ever use a single wheel again
Re: Weight distribution hitches for 28' race trailer. [Re: bigdad] #1736858
01/23/15 04:48 PM
01/23/15 04:48 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: Weight distribution hitches for 28' race trailer. [Re: GTSDave] #1736859
01/23/15 04:56 PM
01/23/15 04:56 PM
Any of the good, better brands, weight distribution hitches should offer several different weight ratings on the bars, 500,750 and 1000 lbs. Buy the thickest heavy duty ones I use to tow my first enclosed 24 ft. 10,000 lb GVW trailer with a 26 Ft Class A 1.5 ton rated IH chassis motorhome, it would be affected by big Semi passing me on the downhills in SO CA like you are expereincing, it would be affected the same way empty, no trailer or towing my 3600 Lb boat and trailer I bought a 1998 3/4 ton Dodge CTD 2 wheel drive and started using the weight 750 lb weight distribution hitch, you will need the matching reciever also once I got the reciever hitch hieght set correclty and the trailer chains on the bars set correctly it was easy and a dream to pull that trailer There is no way I would think of pulling a 28 ft. enclosed car trailer out of my driveway without a weight distrubution hitch on it, no way We bought a 35 ft 5th wheel hitch travel trailer, it pulled way better than the 3 different bumper pull car trailers ever did I'm kind of looking for a longer goose neck or fifth wheel hitch racing trailer with living quarters now, if I can trade my current 24 ft Pace Shadow in on it
Re: Weight distribution hitches for 28' race trailer. [Re: GTSDave] #1736860
01/23/15 05:39 PM
01/23/15 05:39 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I pull a 29' camper with a Tahoe using the Elite EAZ-LIFT hitch assembly. I started pulling the trailer with just one sway bar and it felt a little loose around semis at highway speeds (60mph less than 10mph winds).
I found a few internet threads that say trailers over 28' are recommended to use two sway bar setups. So I then added the second sway bar and I was able to pull it safely at 70-75mph highway speeds with low wind (less than 10mph).
I am now sold on the dual sway bars when traveling on the highway.
Re: Weight distribution hitches for 28' race trailer. [Re: Cab_Burge] #1736861
01/23/15 10:33 PM
01/23/15 10:33 PM
Az
Crizila Offline
Crizila  Offline
Az
If you are race car towing, don't leave home without them. I tow an 18' open trailer (loaded) on very hilly and winding terrain with a Jeep rated at 7500lb.GVWR. I Use 800 lb bars. I do have a set of 1000 pounders, but the 800 lb bars work beautifully. IMO, the big deal is getting the tongue weight correct.
Fastest 300
Re: Weight distribution hitches for 28' race trailer. [Re: Crizila] #1736862
01/23/15 11:13 PM
01/23/15 11:13 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Get one and use it
I had a 28' Prowler travel trailer with a empty GVWR of 7,700# and it towed perfectly behind my 2002 CTD. The truck was equipped with air bags because it was set up for a 5th wheel by the original owner, but I never used them with the load distributing hitch with 1,000# bars. I sometimes wish I still had that truck
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Weight distribution hitches for 28' race trailer. [Re: Polarapete] #1736863
01/24/15 12:03 AM
01/24/15 12:03 AM
GTSDave Offline OP
GTSDave  Offline OP
Thanks for all the replies guys.
I will be getting one now for sure.
I would have gone with the dually but I drive my truck daily, and only use it for pulling once a month or so.
Trying to park a dually at some of the job sites I go in downtown Houston, would be a nightmare.... That is why I went with the single wheel.
My truck is a 2013 that I picked up in Dec of 13. I put just under 32k on it in the last 12 months, so other than the swaying issue while pulling, it has been a perfect fit for me.
Next item is what should I do for tires on the truck. It is a 4x4 and I would like to add something a little bigger than the factory 18" wheel / tire combo. Any recommendations for a LT grip tire that will hold up to towing? Should I just keep a second set of tires and wheels just for the towing?
-Dave
Re: Weight distribution hitches for 28' race trailer. [Re: Crizila] #1736864
01/24/15 12:19 AM
01/24/15 12:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is a MAJOR point.. 10% minimum and no more than
15% on the tongue and proper sized bars for the load
EDIT
Make sure the whole rig is level with the loading
hitch...
in MOST cases that means the top of the ball is at
19" above the ground
Re: Weight distribution hitches for 28' race trailer. [Re: MR_P_BODY] #1736865
01/24/15 12:53 AM
01/24/15 12:53 AM
Az
Crizila Offline
Crizila  Offline
Az
EDIT
hitch...
A level rig is a big point also Even with a walking beam suspension on the trailer, you can still over load / underload trailer tires if the trailer doesn't sit level - and 19" often satisfies that issue. .
Fastest 300
Re: Weight distribution hitches for 28' race trailer. [Re: Crizila] #1736866
01/24/15 01:04 AM
01/24/15 01:04 AM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Check out the shocker hitch.It has a air bag built in that helps swaying and bouncing around.My dad has towed with one for acouple months now and it is great.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Weight distribution hitches for 28' race trailer. [Re: MR_P_BODY] #1736867
01/24/15 03:30 AM
01/24/15 03:30 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
EDIT
hitch...
Tried to get that out of him with my question too, but, he chooses to ignore someone with experience.
Mo' Farts
Re: Weight distribution hitches for 28' race trailer. [Re: Grizzly] #1736868
01/24/15 12:37 PM
01/24/15 12:37 PM
GTSDave Offline OP
GTSDave  Offline OP
It is loaded with the doors centered over the axles. With the additional equipment it is a bit tongue heavy. I have full cabinets with winch, and tools. I also have a generator compartment up front.
Not sure what the weight is on the tongue but it is heavy. This truck squats a bit more than my 01 CTD Camper Special.
-Dave
Re: Weight distribution hitches for 28' race trailer. [Re: GTSDave] #1736869
01/24/15 12:38 PM
01/24/15 12:38 PM
GTSDave Offline OP
GTSDave  Offline OP
Interior.... With my youngest hammin it up.
-Dave
Re: Weight distribution hitches for 28' race trailer. [Re: GTSDave] #1736870
01/24/15 01:06 PM
01/24/15 01:06 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I tow my Dakota on a 18' open trailer behind my 98 Ram 2500, never felt the need to use my EQ hitch but last year I bought a Tilt-A-Hitch off craigslist for 75 bucks, never used it out of fear that it would make towing a challenge. I plan to make a trial run with before I'm all loaded up and committed to going to the track.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
