R5 P7 ET Prediction And billet R5 to Glide adapter pics
#1736221
01/22/15 08:32 AM
01/22/15 08:32 AM
Posts: 35 Down under
OUTLAW565
Down under
Re: R5 P7 ET Prediction And billet R5 to Glide adapter pics
[Re: J_BODY]
#1736224
01/22/15 11:58 AM
01/22/15 11:58 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I'm thinking you need a lower rear gear and higher stall. My guess low 10s, high 9s 130-135 that's a thick plate!
[Re: fishy340]
#1736226
01/22/15 12:55 PM
01/22/15 12:55 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Small tire will not need a ton of gear. Plus it's not a drag radial needing to dead hook. Some wheel speed on launch and the car appears light. Should run. I say 9.0's right out the box. Perfected, 8.7's.
Beautiful adapter. If I were not building a better mousetrap I would want one.
Adapter 1.01.... A neglected issue most racers never consider. A slight bur on the engine to trans mating surface(.010) can move your pump centerline .030". The smaller the bell the more important. No one check the surfaces or considers it. Install an adapter that gets dinged or picks up trash and the problem multiplies. Crank adapters same way. Who checks runnout on flywheels? With proper install and checking it can be of no issue. Adapters IMO are just an added opportunity for centerline and runnout issues. I'm trying to solve that issue as well as some other with my adapter/JW bell/hanging off pump bolts issues. Hope to have it out real soon.
MSD's acquisition of Accell who owns QuickTime has really slowed the process.
But, that is a nice adapter.
Leon
[Re: Leon441]
#1736227
01/23/15 01:12 AM
01/23/15 01:12 AM
Posts: 6,147 Melbourne , Australia
LA360
Those engines need more gears, it would go faster with a 3 speed. Wilson Engineering did a great job with that adapter. I would expect to see time slips in the low 10's/High 9's.
Alan Jones
[Re: LSP]
#1736231
01/23/15 03:50 PM
01/23/15 03:50 PM
Leon441
Lynchburg, VA
People just type away when they don't know the combination you have is a nice way to put it.
With a 26" tire you may find you have too much gear.
Sheet metal intakes have been tried with no improvement on 358's.
[Re: Leon441]
#1736232
01/23/15 03:58 PM
01/23/15 03:58 PM
DemonDust
Menomonee Falls
Says the guy who hasn't had an R5 in his car yet...
