Re: Reproduction Hemi exhaust manifold quality?
[Re: 408cuda]
#1735309
01/21/15 04:42 PM
01/21/15 04:42 PM
Posts: 4,799 ILL
MLR426
ILL
Thanks for the reply. Anyone have any comparison pictures of the two?
They were cast from original manifolds.
MLR426
[Re: MLR426]
#1735310
01/21/15 05:50 PM
01/21/15 05:50 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Some, not all have a few minor problems that can be taken care of easily. The Starter may rub on the manifolds and sometimes the holes used to bolt to the head do not line up 100%. Other wise if they are repros a little bit of port matching would not hurt. Not sure if anyone else has run into more problems
1971 HEMI E BODY REGISTRY
[Re: 68jim]
#1735313
01/22/15 11:23 AM
01/22/15 11:23 AM
Posts: 4,799 ILL
MLR426
ILL
You may need to dress down any casting flash back on the donut shaped collector. Find a piece of scrap pipe - make sure it is very round - to use as a guide so you will end up with a good sealing surface for the head pipes. Just one less headache to deal with...
Yes agree 100 %
MLR426
[Re: MLR426]
#1735314
01/22/15 12:57 PM
01/22/15 12:57 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Yes agree 100 %
MLR426
No question.
[Re: ScottSmith_Harms]
#1735316
01/22/15 01:18 PM
01/22/15 01:18 PM
HEMICUDA
Medina, Ohio
I have 2 different customers who claim that the ears broke off when the tightened the collector to H pipe bolts.
I have x2 sets on cars and that NEVER happened. Now that's first hand experience Scotty boy.
#1735318
01/22/15 03:39 PM
01/22/15 03:39 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Were they using a 1/2" impact gun set on KILL when installing them with the flanges cocked ???
No information on who or how/using what when the manifolds were installed ...
[Re: JohnRR]
#1735320
01/22/15 05:17 PM
01/22/15 05:17 PM
HEMICUDA
Medina, Ohio
Just Scotty talking John.
#1735324
01/22/15 08:34 PM
01/22/15 08:34 PM
HEMICUDA
Medina, Ohio
Nope, guess I'll just stop posting such input unless a full ISO9000 audit has been completed first.
Come on Scotty, you don't need an ISO 9000 certification, just accurate information that typically is acquired from "hands on" experience. He said she said stops at the front door.
