Fuel Pump Push Rod with Roller Cam #1734887
01/20/15 03:52 PM
01/20/15 03:52 PM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
I know there's got to be some experience on this topic. I ran a 440 with a steel push rod in the mechanical fuel pump while running a Comp Street Roller Cam. I ran this combo for 2500 miles or so. There was no visible wear on the cam when dissassembled. I was told that since a roller cam is billet steel, I should be using a brass-tipped push rod. When I went to purchase the part, I noticed a number of bad reviews due to wear. Should I continue to use the original, stock push rod? Are there options on the brass-tipped rod? What reccomendations do you have? Thanks in advance for your help.
Re: Fuel Pump Push Rod with Roller Cam [Re: Tommy D] #1734888
01/20/15 09:11 PM
01/20/15 09:11 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
i have been running the stock one for years on a crane billet steel roller
Re: Fuel Pump Push Rod with Roller Cam [Re: BIGSTROKER] #1734889
01/21/15 10:08 AM
01/21/15 10:08 AM
Tommy D Offline OP
Tommy D  Offline OP
Thanks. I think I'll continue to go that same route. I appreciate your reply. Tom
Re: Fuel Pump Push Rod with Roller Cam [Re: Tommy D] #1734890
01/21/15 01:34 PM
01/21/15 01:34 PM
usa
smos001 Offline
smos001  Offline
usa
I contacted several Cam manufactures and asked about bronze vs. stock steel fuel pushrods with steel billeted cams. All of them said that I had to use a Bronze pushrod.They said I would damage the fuel lobe on the cam.
That being said, my engine builder said that mopar's have plenty of oil around that lobe and the steel on steel should not wear. However, I thought about going to a bronze pushrod. But I have heard that the pushrod could (rare) mushroom at the end and then you have a hard time replacing at the intervals you need to. You need to check the rod every once in awhile. They are sacrificial rods.
So, I decided to avoid the whole issue and go electric fuel pump.
I have too much invested in my engine to take a chance.
Re: Fuel Pump Push Rod with Roller Cam [Re: Tommy D] #1734891
01/21/15 04:00 PM
01/21/15 04:00 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I use the recomended bronze tip from Comp Cam and after two summers of use in my rb stroker i pulled it out after i had invested in a new one but to my surprice there were no wear on the one in the engine ! I wouldent dare to use a steel tip
