Aluminum timing cover BB #1731903
01/17/15 09:42 AM
01/17/15 09:42 AM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
Looking for one because of roller cam button. Who makes them?
Re: Aluminum timing cover BB [Re: Cuda367] #1731904
01/17/15 10:26 AM
01/17/15 10:26 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Here ya go:
http://www.manciniracing.com/mabbialtico.html
I'm using one of these with a hydraulic roller and cam button. No problems. A little expensive but worth it in my opinion.
Re: Aluminum timing cover BB [Re: TooMany62s] #1731905
01/17/15 12:26 PM
01/17/15 12:26 PM
I got mine from Nick at Compuflow.
Re: Aluminum timing cover BB [Re: ] #1731906
01/17/15 01:14 PM
01/17/15 01:14 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I had and liked the Indy ones on my Mopar engines.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Aluminum timing cover BB [Re: TooMany62s] #1731907
01/17/15 01:17 PM
01/17/15 01:17 PM
NC
440Jim Offline
440Jim  Offline
NC
Here ya go:
Mancini also carries the Indy plain cast aluminum timing cover for $125
http://www.manciniracing.com/inbhecaaltic.html
Re: Aluminum timing cover BB [Re: Cuda367] #1731908
01/17/15 02:31 PM
01/17/15 02:31 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
used this one ok no problems 3 years works with cam button to.. http://store.440source.com/Fabricated-Aluminum-Timing-Cover/productinfo/200-1089/
Re: Aluminum timing cover BB [Re: TooMany62s] #1731909
01/17/15 05:51 PM
01/17/15 05:51 PM
AndyF Offline
AndyF  Offline
The Mancini webpage info needs to be updated. Best place for info is my website. I also have two piece covers for the SB guys.
http://arengineering.com/home-page/engine-parts/
Re: Aluminum timing cover BB [Re: MRMOPAR622] #1731910
01/17/15 07:49 PM
01/17/15 07:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Indy covers don't fit under stock style water pumps. Muscle Motors used to sell a really nice cast cover for about $100. that fits great.
Re: Aluminum timing cover BB [Re: Stanton] #1731911
01/17/15 09:14 PM
01/17/15 09:14 PM
AndyF Offline
AndyF  Offline
Right, that was one reason why I started to make my own. I designed my billet cover to be low enough to fit under a MP aluminum water pump housing. I also added the adjustable TDC pointer which the Indy cover doesn't have and I used the more modern front loaded seal design. I also include a setup plate so a guy can check the end play on the camshaft.
Re: Aluminum timing cover BB [Re: Cuda367] #1731912
01/17/15 09:57 PM
01/17/15 09:57 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I have built several BB roller engines with the stock timing cover. I fit a washer on the back of the water pump so the timing cover rests onto the washer if the cam walks forward.
Never had a problem
Re: Aluminum timing cover BB [Re: Stanton] #1731913
01/17/15 10:54 PM
01/17/15 10:54 PM
NC
440Jim Offline
440Jim  Offline
NC
Since I have a front engine plate (1-piece elephant ears type), the Indy cover clears the MP aluminum water pump housing on my race car.
Re: Aluminum timing cover BB [Re: 440Jim] #1731914
01/18/15 12:09 PM
01/18/15 12:09 PM
ky
68roadrunner Offline
ky
you had to have the right balancer to fit that cover didnt you? with a longer snout
Re: Aluminum timing cover BB [Re: Cuda367] #1731915
01/18/15 04:10 PM
01/18/15 04:10 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Re: Aluminum timing cover BB [Re: Cuda367] #1731916
01/18/15 04:11 PM
01/18/15 04:11 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Re: Aluminum timing cover BB [Re: MartyQ] #1731917
01/18/15 09:30 PM
01/18/15 09:30 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Comp-flow's engine plates look's nice also
Re: Aluminum timing cover BB [Re: 68roadrunner] #1731918
01/18/15 09:51 PM
01/18/15 09:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
They make a spacer you can install behind your balancer.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aluminum timing cover BB [Re: Cuda367] #1731919
01/19/15 02:17 AM
01/19/15 02:17 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Aluminum timing cover BB [Re: 68roadrunner] #1731920
01/19/15 02:41 PM
01/19/15 02:41 PM
NC
440Jim Offline
440Jim  Offline
NC
I am using the same old Fluidamper I have used on all my builds.
