71 charger 440 A/C, P/S, and alternator routing #1731839
01/17/15 12:00 AM
01/17/15 12:00 AM
Finally a HUSKER again
Moparnut426 Offline OP
I think I have some wrong stuff here. I have a 2 pulley fan pulley, I think that's wrong, and I think 2 belts should be the same on the alternator, and 1 small fan belt on a tensioner, and the P/S belt should be 1 belt from the crank to the P/S pulley, is that correct?
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: Moparnut426] #1731840
01/17/15 12:52 AM
01/17/15 12:52 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Question: Is the Air Conditioner Compressor still in place?
The A/C and Non-A/C use different pulley's. The water pump/Fan and crank pulley's are different. There is an idler pully on a bracket and other different brackets too.
Do you have access to someone else's similar car to compare?
If you can find the Factory Service Manual and Parts Manual that might help too. The A/C on my Charger is in storage in the garage and has been for decades.
When I first switched over to non-A/C, I tried using bushings, etc, to get the bracket belt alignment correct. Eventually, I got the correct pulley's and that solved the problem.
There are also aftermarket pulley sets.
Maybe someone can post pictures of their engine compartments?
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: D_C] #1731841
01/17/15 01:28 AM
01/17/15 01:28 AM
D_C Offline
D_C  Offline
Here is a photo of a dilapidated 440 I found on the Internet, but it shows roughly the pulley's and brackets involved:
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: D_C] #1731842
01/17/15 01:38 AM
01/17/15 01:38 AM
Thanks!
I saw that too, I just had hoped the water pump pulley was correct, must be, that means I have the wrong water pump pulley, and possible the wrong crank pulley.
THis car still has A/C on it.
KAsey
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: Moparnut426] #1731843
01/17/15 02:14 AM
01/17/15 02:14 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Here are some pictures
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: moparmarks] #1731844
01/17/15 02:15 AM
01/17/15 02:15 AM
moparmarks Offline
moparmarks  Offline
Nutter one
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: Moparnut426] #1731845
01/17/15 01:14 PM
01/17/15 01:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
If you need pulleys I have the pulleys off my old 71
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: dart4forte] #1731846
01/18/15 07:20 PM
01/18/15 07:20 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Anyone know any part#s for some NON-ribbed AC belts other than the repops????
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: Moparnut426] #1731847
01/19/15 02:25 AM
01/19/15 02:25 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
There's a double fan pulley available that goes in-route with the power steering/crank belt to aid in belt slippage on high HP applications..
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: screamindriver] #1731848
01/19/15 11:34 AM
01/19/15 11:34 AM
moparmarks Offline
moparmarks  Offline
Really??? Not what the books show. All my 70-2 440 HP's are like what I've shown. Got some pictures?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: moparmarks] #1731849
01/19/15 05:35 PM
01/19/15 05:35 PM
Chilly Northern, Minn.
71 Charger R/T Offline
My '71 is an R/T (HP) and it is configured just like Moparmarks is………..
Re: 71 charger 440 A/C, P/S, and alternator routing [Re: 71 Charger R/T] #1731850
01/20/15 01:29 AM
01/20/15 01:29 AM
Harrisburg, Pa.
Harrisburg, Pa.
Sorry guys I should have been more specific...It's an aftermarket pulley..Here it is.. LINK ...I was just pointing out there is one out there and it looks stock...Was'nt sure if the pulley in question might have been one of those...I had to use one on a 6bbl engine that had AC and kept smoking the belt when it kicked in... I do have pics of it installed if you still want to see it I'll dig them out...It would certainly throw someone off if you did'nt know it's available...
