best big block head for the money #1730090
01/14/15 11:04 PM
01/14/15 11:04 PM
Ky
moparmafia Offline OP
Ky
Trying to figure out which way to go for a 10.5 heads up class at our local track. I had a indy aluminum block but sold it and just saving money until i can find the right deal. what head would be best on a budget but still be able to make the best power for a power adder class at about 3200 lbs. The heads i am trying to decide between is the b1 original or the b1 m/c. or the 572-13 and the 600-13. I have no clue the difference in the 600-13 and the 600-13x and really didnt want to call indy. I have seen several sets of the 572, b1 original and the m/c head used already ported within my budget and i leave out the predator and pso etc because used they are still too expensive if you can even find them. I am thinking the best way is the 600-13 that uses the 4.84 bore spacing block but i need some advice from people with experience.
Re: best big block head for the money [Re: moparmafia] #1730091
01/15/15 01:28 AM
01/15/15 01:28 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
The 68 Barracuda called Hustlin Hoosire that Mike runs has a BB and I'm pretty sure he runs the 600-13 head but not sure if it is the x head or not. I have seen him run some mid 5.30's with it NA. I guess you could call Best Machine as they are the ones that built his engine and they could at least lead you in the right direction for what you want to acheive.
Re: best big block head for the money [Re: max_maniac] #1730092
01/15/15 02:20 AM
01/15/15 02:20 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would say the B1-MC will make the most power. You will have to spend money on porting.
Re: best big block head for the money [Re: moparmafia] #1730093
01/15/15 12:20 PM
01/15/15 12:20 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What kind of power adder are you going to use? Bigtime uses 572 indy heads and makes more then enough power with his procharger. Gary Robbins uses B1 orginals with nitrous and holds the record in Monster Mopar 10.5.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: best big block head for the money [Re: 1967dartgt] #1730094
01/15/15 03:42 PM
01/15/15 03:42 PM
Ky
Ky
I was going with a nitrous setup because of the initial cost and i have some friends that are very experienced with it.
Re: best big block head for the money [Re: moparmafia] #1730095
01/16/15 12:06 AM
01/16/15 12:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
B1MC or a Predator
Re: best big block head for the money [Re: max_maniac] #1730096
01/17/15 03:49 PM
01/17/15 03:49 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
He runs the 600-13x.
I can tell you we have been faster with a b1 original 557 then with a 588 572-13 motor; both all aluminum.
I would think the b1 mc head would be faster.. Just look at al''s motor!!
Casey
