Re: 727 Trans pan
[Re: RAY1969CARS]
#1729496
01/14/15 12:35 AM
01/14/15 12:35 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I have the B&M pan, it is nice but to deep and I had to raise my truck up some to clear speed bumps and driveways ![](/ubbthreads/images/graemlins/crazy.gif) I want to get another cast aluminum pan but one not so deep for more ground clearance.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: 727 Trans pan
[Re: MoParFish]
#1729500
01/14/15 09:20 AM
01/14/15 09:20 AM
Posts: 9,883 MI, usa
dvw
MI, usa
I just run stock overdrive pans. Same as on my 97 2500. I just add a drain plug and filter extension on a 727. http://www.ebay.com/itm/351218654172
I run these as well. They are 1" deeper than the normal deep pan. Had to fab an additional filter spacer. Been buying them for about $35. Doug
Re: 727 Trans pan
[Re: hemi-itis]
#1729502
01/14/15 01:57 PM
01/14/15 01:57 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run the B&M finned aluminum pan as well. Good quality aluminum pan at a decent price. I noticed a 10-degree difference in fluid temp with it, from a stock pan.
Re: 727 Trans pan
[Re: StealthWedge67]
#1729503
01/14/15 05:19 PM
01/14/15 05:19 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Much less prone to leaking like a steel pan.
Re: 727 Trans pan
[Re: an8sec70cuda]
#1729504
01/14/15 08:19 PM
01/14/15 08:19 PM
dvw
MI, usa
I run the B&M on my street car. Nice pan but it is heavy. Neither pan leaks a drop. Doug
